K042
K042
    M5STACK(明栈)
    开关 接口 M5Atom 平台评估扩展板
K042 数据手册
ATOM SWITCH Kit SKU:K042 Description ATOM SWITCH is a bi-directional control programable switch for the M5ATOM. It can be connected to bi-directional AC circuits for simultaneous on-off control. The on-board relay can support up to 250V / 10A AC(Instantaneous current 16A). Built in step-down module can provide 5V / 1A DC power supply for ATOM. In order to ensure safe use, its DC circuit has overheating and short circuit protection functions. In order to facilitate the use of users in industrial scenarios, an SP485EE level-conversion IC is built in. There are also a set of RS485 interfaces provided for the user to connect RS485 equipment.RS485 has the ability to supply power to ATOM, the support voltage is 9-24V. In addition, a set of HY2.0 interfaces is also provided for connecting I2C peripheral equipment or general I/O equipment. With the Bluetooth and WiFi functions of M5ATOM, you can easily setup a remote control switch. If you have multiple M5ATOM HUB SWITCH modules, you can set them up in parallel through the RS485 interface. Product Features Compatible ATOM Matrix/ATOM Lite Built-in AC-DC circuit 2-way relay Built-in RS485 level-conversion, supporting Modbus HY2.0 port extend Short circuit protection Remote control via Bluetooth, WiFi and RS485 Include 1x ATOM SWITCH 1x ATOM Lite 4x Magnet 1x double-side tape 1x DIN Rail 1x 3.96*4P plug 3x 3.96*3P plug 1x M4 Hex Key 1x M2 Hex Key 2x M4*10mm Hexagon countersunk screw 1x M2*20mm Hexagon socket cup head machine screw Applications Intelligent switch Switch & Switch-D Compared / Switch Switch-D Relay Current AC 250V/10A AC 250V/5A Power Input HT3.96R 2P HT3.96R 3P Relay Interface (NO,NC,COM) x2 (NO(connect to the AC power L line) , COM(connect to the AC power N line)) x2 Please refer to the figure below for details ? The kit is equipped with a guide rail firmware fixture, please refer to the following figure for the specific installation method: Specification Resources Parameter Relay AC 250V/10A(Instantaneous current 16A), DC 5V/1A Switch power supply(AC-DC) AC 250V-DC 5V RS485 supply voltage 9V-24V Interface 1x HY2.0(PORT A), 1x HT3.96R 4P(RS485), 2x HT3.96R 3P(Relay), 1x HT3.96R 3P(AC/DC IN) Net weight 134g Gross weight 158g Product Size 72*40*30mm Package Size 104*77*35mm Case material Plastic ( PC ) EasyLoader EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification. Download Windows Version Easyloader Download MacOS Version Easyloader Description: ? Press the key to control the switch. The status of breathing light indicates the relay serial number and switch status. When the red light or green light is on, press the key to switch the status Related Link Datasheet SP485EE Pin Map ATOM 22 19 33 23 25 21 ATOM HUB SWITCH Relay1 Relay2 RX TX SDA SCL Schematic Example Arduino Click here to download the Arduino example UIFlow Click here to download the UIFlow example
很抱歉,暂时无法提供与“K042”相匹配的价格&库存,您可以联系我们找货
