K043
K043
    M5STACK(明栈)
    GPS 传感器 M5Atom 平台评估扩展板
K043 数据手册
ATOM GPS Kit SKU:K043 Description ATOM GPS is a GPS positioning module wich is part of the M5 atomic series. The navigation chip is m8030-kt, which has built-in flash and a coin cell battery, which can save the users configuration. It adopts NMEA-0183 protocol output, supports GPS, GLONASS, Galileo, BDS, SBAS and QZSS satellite systems, has 72 search channels, an adjustable refresh rate, and can be widely used in vehicle monitoring such as bus stop reporting, vehicle navigation, ship navigation, track tracking and other applications. In addition, a self elastic TF(MicroSD) card slot is built in. It is possible to read and write GPS and other file data, for example, you could export GPS data in a specific format to view the motion tracking in the map software, or read and write files as a common card reader. UART Parameter setting: Baud rate(default: 9600bps) Start bit(1 bit) Stop bit(1 bit) Check bit(None) Product Features Compatible with Atom Matrix/Atom Lite High signal acquisition sensitivity Support single system positioning of BDS / GPS / GLONASS / Galileo / SBAS / QZSS multiple satellite navigation systems Built in self elastic TF (microSD) card slot Low power Include 1x ATOM GPS 1x ATOM Lite 1x Hex Key 1x M2*3mm Hexagon self tapping screw 1x M2*8mm Hexagon socket cup head machine screw 1x TYPE-C USB Cable(20cm) Applications Vehicle and ship positioning and navigation Track record File reading and writing Specification Resources Parameter Frequency GPS L1, GLONASS L1, BDS B1, GALILEO E1, SBAS L1, QZSS L1 accuracy Accuracy Horizontal: 2m, Speed: 0.1m/s, Time: 1us Channels 72 search channel Update frequency 1-10Hz Maximum height 50000m Maximum speed 515m/s Maximum < 4g acceleration Sensitivity Trace: - 167dbm, capture: - 160dBm, cold start: - 148dbm, hot start: - 156dbm Start time Cold start: 26 seconds, warm start: 25 seconds, hot start: 1 second Baud rate default: 9600bps Output protocol NMEA-0183 NMEA sentence RMC, VTG, GGA, GSA, GSV, GLL FLASH 4M FLASH TX: the power on blue light flashes, indicating that there is data output, PPS:3D Blink after positioning, and it will not Indicator light light if it is not positioned Working -40°C - 85°C temperature Net weight 28g Gross weight 38g Product size 24*48*18mm Package size 54*54*20mm EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification. Download Windows Version Easyloader ? Download MacOS Version Easyloader Description: Connect Bluetooth serial port tool of mobile phone to view GPS information Peripherals Pin Map ATOM GPIO19 GPIO22 GPIO23 GPIO33 ATOM GPS MOSI TX CLK MISO Schematic Related Link CASIC Multimode satellite navigation receiver protocol specification Example Arduino Click here to download the Arduino example
很抱歉,暂时无法提供与“K043”相匹配的价格&库存,您可以联系我们找货
