ATOM STEPMOTOR Kit
SKU:K047
Description
ATOM STEPMOTOR is a stepper motor driver module suitable for Atom Lite only, with built-in DRV8825 driver chip, which can be used to drive a
stepper motor. By adjusting the variable resistance, it can provide a maximum driving current of 1.2A. The chip has its own over-current protection
function. A DIP switch on board can adjust the step number flexibly. Built in DC-DC,the external power supply can supply power to ATOM,drive
motor needs an external power supply(9-18V).
Product Features
Adapt to Atom Lite only
Built in DC-DC
Up to 1/32 micro-stepper
Maximum 1.2A drive current
Working status indicator
Include
1x ATOM Lite
1x Atom Step Motor
1x Type-C Cable(20cm)
1x M2*8 Screw
1x Hex key
Applications
Stepper motor controller
Specification
Resources
Parameter
Micro-Stepping Levels
1/32 Step
Output current
Full-scale 1.2A
Supply voltage
9-18V
External port
KF128L 2.54 6P
Net weight
17g
Gross weight
53g
Product size
48*24*18mm
Package size
55*55*20mm
Case material
Plastic ( PC )
EasyLoader
EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the
main control by simple steps to perform a series of function verification.
Download Windows Version Easyloader
Download MacOS Version Easyloader
Description:
Related Link
Datasheet
DRV8825
Pin Map
ATOM Pin
G25
G21
G22
G19
G23
ATOMIC StepMotor
FLT
RST
EN
STP
DIR
Micro-stepping Setting
DIP Switch
1
2
3
DIP Switch
Full-step
1
Low
2
Low
3
Low
Half-step
High
LoW
LoW
1/4 step
Low
High
Low
1/8 step
High
High
Low
1/16 step
Low
Low
High
1/32 step
Hight
Low
High
1/32 step
Low
High
High
1/32 step
High
High
High
Decay mode
DIP Switch
4
Slow Decay
Low
Fast Decay
High
Schematic
Example
Arduino
Click here to get Arduino example
UIFlow
Clicke here to get UIFlow example
很抱歉,暂时无法提供与“K047”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+206.545561+26.72218
