K059
K059
    M5STACK(明栈)
    - SIM7020G 收发器 评估板
K059 数据手册
ATOM DTU NB SKU:K059 Description ATOM DTU NB is a programmable data transmission unit (DTU) that integrates NB-IoT communication functions. The built-in SIM7020G module covers most of the Cat-NB frequency bands and integrates the SMA external antenna interface to improve the communication quality and signal stability of the device. Unlike the DTU, which generally only has the function of data transparent transmission, the ATOM DTU series adopts a more open architecture design. The controller ATOM LITE can modify the program at will according to the actual business, and the whole machine reserves a variety of interfaces (RS485, I2C, custom interface) for users to expand, which is convenient for the rapid access of sensors and actuators. The self-contained guide rail clamping structure is perfectly embedded in various industrial control sites. ATOM DTU NB is very suitable for various low-latency, low-throughput application scenarios (such as remote control, asset tracking, remote monitoring, remote medical treatment, shared bicycles, etc.). Product Features SIM7020G/Global version/Multi-band support RS485 communication interface (with 12V input interface, internal integrated DCDC step-down 5V) Modbus Master/slave Strong signal access capability AT command control SIM card type: MicroSIM External antenna: SMA antenna interface Grove expansion interface: I2C x1 Custom x1 Serial communication: UART 115200bps Self-contained rail clamping Cat-NB frequency band: B1/B2/B3/B4/B5/B8/ B12/B13/B17/B18/B19/ B20/B25/B26/B28/ B66/B70/B71/B85 Data transmission (kbps): 126(DL)/150(UL) Network protocol: TCP/UDP/HTTP/HTTPS/ TLS/DTLS/DNS/NTP/ PING/LWM2M/COAP/ MQTT/MQTTS Includes 1x ATOM DTU NB 1x SMA antenna 1x SMA red cap 1x M2 hexagon wrench 1x M2x16 screw 1x 3.96-4P terminal Application Smart meter Remote monitoring Shared bicycles Certification RoHS\REACH\RCM\Telstra\CE(RED)\GCF\ATEX\TIM\Deutsche Telekom\Vodafone\FCC\PTCRB\T-Mobile\IC Operator certification Telstra*/Vodafone/Deutsche Telekom Specifications Resources Parameter Module SIM7020G Support Cat-NB frequency band B1/B2/B3/B4/B5/B8/ B12/B13/B17/B18/B19/ B20/B25/B26/B28/ B66/B70/B71/B85 Network protocol TCP/UDP/HTTP/HTTPS/ TLS/DTLS/DNS/NTP/ PING/LWM2M/COAP/ MQTT/MQTTS communication Resources UART 115200bps Parameter Net weight 32g Gross weight 40g Product Size 64 * 24 * 29mm Package Size 91 * 42 * 24.5mm Related Link Datasheet SIM7020 Series datasheet SIM7020 Series_Ayla_Application Note_V1.03 SIM7020 Series_CTBURST_Application Note_V1.01 SIM7020 Series_CoAP_Application Note_V1.03 SIM7020 Series_EAT_Environment & Compilation & Burning Guide_V1.02. SIM7020 Series_FOTA_Application_Note_V1.02 SIM7020 Series_HTTP(S)_Application Note_V1.04 SIM7020 Series_LWM2M_Application Note_V1.03 SIM7020 Series_Low Power Mode_Application Note_V1.05 SIM7020 Series_MQTT(S)_Application Note_V1.05 SIM7020 Series_NVRAM_Application Note_V1.02 SIM7020 Series_SAT_Application Note_V1.01 SIM7020 Series_SNTP_Application Note_V1.03 SIM7020 Series_TCPIP_Application Note_V1.04 AT Command SIM7020 Series_AT Command Manual_V1.05 Pin mapping SIMCOM7020G ATOM G22(TX) G19(RX) 5V GND SIMCOM7020G RX TX VIN GND RS485 ATOM G23 G33 5V GND RS485 TX RX VIN GND ATOM G25 G21 5V GND I2C SDA SCL VIN GND I2C Schematic Example UIFlow Feature Introduction Init NB-IoT DTU Initialize NB-IoT DTU Power down module Power down the module Reset module Reset the module Set command echo mode Set command echo Check module status Check status of the module Check single quality Check quality of the single Check network registration Check the registration of the network Check GPRS network registration Check the registration of the GPRS network Enable PDP context Enable Packet Data Protocol CoAP connect ip port Establish CoAP connection CoAP GET url security Use GET to make a request CoAP POST url payload content format security Use POST to make a request CoAP PUT url payload content format security Use PUT to make a request CoAP destory Destroy CoAP connection MQTT connect server port client id username password keepalive Use the MQTT protocol to connect to the server MQTT disconnect Disconnect MQTT connection MQTT subscribe topic QoS Subscribe a topic MQTT subscribe callback topic msg Echo the topic and content of the subscription MQTT unsubscribe topic Unsubscribe the topic MQTT publish topic payload Qos Publish a topic MQTT check connection Check MQTT connection MQTT poll downlink message Poll downlink message RS485 write a line Write a line of data RS485 write Data input RS485 write raw data create list with Write raw data in list form RS485 read all Read all data of RS485 RS485 read characters Read the number of characters of RS485 RS485 read line Read the data of a line of RS485 Remain cache Remian cache of RS485 Read coils slave address starting address coil qty Read the data of the coils Read discrete inputs slave address starting address input qty Read the data of the discrete inputs Read holding registers slave address starting address register qty signed Read the data of the holding registers Read input registers slave address starting address register qty signed Read the data of the input registers Write single coil slave address output address output value Write data to a single coil Write single register slave address register address register value signed Write data to a single register Write multiple coils slave address starting address output value Write data to multiple coils Write multiple register slave address starting address register value signed Write datat to multiple register Usage Receive the information published by the subscribed topic, when receiving the 'ON' or 'OFF' command, turn on or off the LED indicator, and respond to the topic MQTT TEST Download the ATOM DTU NB M5F program file Arduino ATOM DTU NB - MQTT ATOM DTU NB - HTTP Video
很抱歉,暂时无法提供与“K059”相匹配的价格&库存,您可以联系我们找货
