K061
K061
    M5STACK(明栈)
    - ASR6501 收发器; LoRa®(LoRaWAN™) 915MHz 评估板
K061 数据手册
ATOM DTU LoRaWAN915 SKU:K061 Description ATOM DTU LoRaWAN915 is a LoRaWAN Programmable Data Transmission Unit (DTU) suitable for 915MHz frequency. The module adopts the ASR6501 scheme, which supports long-distance communication and has both ultra-low power consumption and high sensitivity. The module integrates the LoRaWAN protocol stack and adopts a serial communication interface (using AT command set for control). When used, it can be used as a collection node to access a large number of gateways for data collection and management. Integrate SMA external antenna interface to improve the communication quality and signal stability of the device. Unlike the DTU which generally only has the function of data transparent transmission, the ATOM DTU series adopts a more open architecture design. The controller ATOM LITE can modify the program at will according to the actual business. The whole machine reserves a variety of interfaces (RS485, I2C, custom interface) for user expansion, which is convenient for the rapid access of sensors and actuators. With its own guide rail clamping structure, it is perfectly embedded in various industrial control sites. Product Features ASR6501 Operating frequency: 915MHz Serial communication: UART 115200bps (AT command) With super anti-interference ability, able to work normally in complex interference environment RS485 communication interface (with 12V input interface, internal integrated DCDC step-down 5V) Modbus Master/slave Strong signal access capability External antenna: SMA antenna interface Grove expansion interface: -I2C x1 -Custom x1 Self-contained rail clamping Includes 1x ATOM DTU LoRaWAN470 1x SMA antenna 1x SMA red cap 1x M2 hexagon wrench 1x M2x16 screw 1x 3.96-4P terminal Application Automatic remote meter reading Intelligent traffic intelligent parking lot Remote irrigation and environmental monitoring 915MHz supported countries Argentina/Australia/Bolivia/Brazil/Canada/Chile/Colombia/Dominican Republic/Ecuador/Greece Guatemala/Honduras/Jamaica/Mexico/New Zealand/Nicaragua/Panama/Panama/Paraguay/Peru/Papua New Guinea/El Salvador/USA/ Uruguay Specifications Resources Parameter Communication chip ASR6501 Operating frequency 915MHz Minimum receiving sensitivity -137dBm (SF=12/BW=125KHz) Maximum transmit power +21dBm communication UART 115200bps Net weight 32g Gross weight 40g Product Size 64 * 24 * 29mm Package Size 91 * 42 * 24.5mm Pin mapping LoRaWAN915 ATOM G22(TX) G19(RX) 5V GND ATOM G22(TX) G19(RX) 5V GND LoRaWAN915 RX TX VIN GND RS485 ATOM G23 G33 5V GND RS485 TX RX VIN GND ATOM G25 G21 5V GND I2C SDA SCL VIN GND I2C Related Link COM.LoRaWAN915 AT command set LoRaWAN Regional parameters Schematic Example Arduino ATOM DTU LoRaWAN - Send Msg to Gateway
很抱歉,暂时无法提供与“K061”相匹配的价格&库存,您可以联系我们找货
K061
  • 1+287.240691+37.08037
库存:1
