K065
K065
    M5STACK(明栈)
    EG27324,FDD8447L 电机控制器/驱动器 电源管理 M5Stack 平台评估扩展板
K065 数据手册
ATOM PWM SKU:K065 Description The ATOM PWM is a single-channel PWM regulate DC Driver with built-in MOSFET load capacity up to 12V@100W, suitable for high-power DC motor PWM speed control and industrial heating wire control applications. Using ATOM LITE as the core controller (built-in ESP32), it has a wide PWM dynamic adjustment range (e.g., frequency of 5 kHz, duty cycle adjustment range 0-100%, resolution up to 13bit), and combined with the built-in WIFI & Bluetooth function, it can also easily achieve remote control. Supports UIFlow graphical programming for easy configuration of signal output and function expansion. Product Features Single channel low latency PWM signal output High power MOSFET, output capacity 12V@100W Reserved 1xGROVE expansion interface Built-in DC-DC (12V->5V) conversion circuit Easy installation, simple operation All-in-one design with protective cover Development platform: Arduino/UIFlow Included 1x ATOM PWM 1x ATOM LITE 1x M2 Hex Wrench 1x M2*8 cup head Machine screw 1x 3.96-4P terminal 1x TYPE-C USB data cable (20cm) Applications DC motor control Light control Heater control DC Load Specifications Specification Parameter Driver Chip EG27324 MOSFET FDD8447L Maximum Output Power 100W Input Voltage Range DC 12V-24V Number of Drive Channels 1 Net Weight 28.9g Gross Weight 37.3g Product Dimensions 24 * 48 * 18mm Package Size 54 * 54 * 20mm Common Frequency and Resolution LEDC Clock Source LEDC Output (PWM) Frequency Highest Resolution APB_CLK (80 MHz) 1 kHz 1/65536 (16 bit) APB_CLK (80 MHz) 5 kHz 1/8192 (13 bit) APB_CLK (80 MHz) 10 kHz 1/4096 (12 bit) RTC8M_CLK (8 MHz) 1 kHz 1/4096 (12 bit) RTC8M_CLK (8 MHz) 8 kHz 1/512 (9 bit) REF_TICK (1 MHz) 1 kHz 1/512 (9 bit) Related Links Datasheet FDD8447L EG27324 ME3116AM6G Pin Mapping ATOM G22 EG27324 INA Schematic Example UIFlow View UIFlow-PWM control documentation Arduino #include #define SIGNAL 22 int freq = 10000; int ledChannel1 = 0; int resolution = 10; void setup() { ledcSetup(ledChannel1, freq, resolution); ledcAttachPin(SIGNAL, ledChannel1); } void loop() { for(int i=0; i < 500; i++){ ledcWrite(ledChannel1, i); delay(2); } for(int i=500; i > 0; i--){ ledcWrite(ledChannel1, i); delay(2); } } Video
很抱歉,暂时无法提供与“K065”相匹配的价格&库存,您可以联系我们找货
