M020
M020
    M5STACK(明栈)
    MAX3421E USB 主机板 接口 M5Stack 平台评估扩展板
M020 数据手册
Module USB SKU:M020 Description USB is a USB driver module, integrated MAX3421E which adds USB host or peripheral capability to any system with an SPI interface. Ever up for adding the standard USB features on your project? this M5 moudle is the perfect solution. Product Features • • • • • • Series Protocol: SPI6 1x UAB stadard A port 10x extended GPIO pins extended 3v3, 5v & GND Product Size:54.2mm x 54.2mm x 12.8mm Product weight:14.5g Including • 1x M5Stack USB Module Applications • • USB keylogger Read and write U disk using M5Core Related Link • Datasheet - MAX3421E EasyLoader click to download EasyLoader 1.EasyLoader is a simple and fast program burner. Every product page in EasyLoader provides a product-related case program. It can be burned to the master through simple steps, and a series of function verification can be performed.(Currently EasyLoader is only available for Windows OS) 2.After downloading the software, double-click to run the application, connect the M5 device to the computer via the data cable, select the port parameters, and click "Burn" to start burning. 3.The CP210X (USB driver) needs to be installed before the EasyLoader is burned. Click here to view the driver installation tutorial Example To get complete code, please click here NOTE: Before compile this example code, you need to download the corresponding USB library from here. Unzip and copy this library folder to Arduino library path.( This is my pathC:\Users\\Documents\Arduino\libraries) Download the example usb_mouse.ino Plug the USB mouse into USB A port. • Hold down the left button to draw white lines. • Hold down the right button to draw green line. • Press the middle wheel button to clear the screen. Schematic https://docs.m5stack.com/#/en/module/usb/4-10-20
很抱歉,暂时无法提供与“M020”相匹配的价格&库存,您可以联系我们找货
