M029
M029
    M5STACK(明栈)
    LoRa Protoboard M5Stack 平台评估扩展板
M029 数据手册
Module LoRa868 SKU:M029 Description LoRa868 is a LoRa communication module in the M5Stack stack module series (working frequency is 868MHz). A certain expansion space is reserved on the module, which defeats you for more functional design. For wireless communication or projects with more customized elements, the LoRa868 module will be a suitable choice. Product Features LoRa Module: Ra-01H Communication Protocol: SPI Universal Perfboard Working Frequency: 803~930 MHz Supports: FSK, GFSK, MSK, GMSK, LoRa™ and OOK modulation modes Receive sensitivity: lowest to -141 dBm Programmable bit rate up to 300Kbps Built-in FPC Antenna External IPX Antenna connector Program platform: Arduino Include 1x M5Stack LoRa868 Module Applications Remote electricity meter reading Home automation Remote irrigation system Remote irrigation system Specification Resources Parameter Net weight 14g Gross weight 24g Product Size 54.2*54.2*13mm Package Size 60*57*17mm Related Link LoRa Info (LoRa) LoRaWAN Regional Parameters EasyLoader EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification. Download Windows Version Easyloader ? Download MacOS Version Easyloader Description: Two devices will send and receive messages from each other. Example Arduino IDE These are the point-to-point communication examples between two LORA868 modules. The LoRa nodes send and receive messages. Blue string indicates sending succeed. Yellow string display the received messages. Red string indicates initialization failed. Schematic MBUS PinMap Last updated: 2020-12-28
很抱歉,暂时无法提供与“M029”相匹配的价格&库存,您可以联系我们找货
