M031-Z
M031-Z
    M5STACK(明栈)
    - CC2630F128 802.15.4/Zigbee 2.405GHz ~ 2.48GHz 评估板
M031-Z 数据手册
COM.Zigbee SKU:M031-Z Description COM.Zigbee is a Zigbee self-organizing network communication module launched by M5Stack. The module adopts the CC2630F128 solution, internally integrates the Zigbee protocol stack, and opens the serial communication interface. Integrated external antenna, single node stable communication distance up to 1km, 200-level router depth, through the MESH networking mode, you can extend your IoT application in a wide range, with both ultra-low power consumption and high sensitivity. The Zigbee network can support hundreds of nodes and has enhanced security features. It can provide complete and interoperable IoT solutions for home and building automation. Notice ? When used with the FIRE main control, due to the PSRAM pin conflict, please switch the DIP switch pins of the module base to TX(0/13), RX(5/15), and the device can use USB/ External DC is used for power supply. When used with Core2 series main control, due to the different order of the base pin array, COM.X base pins TX(16), ? RX(17) correspond to the actual pins TX(14), RX of the Core2 main control (13) The equipment needs to use external DC for power supply. Note: When using the CORE2 or CORE2-FOR-AWS main control to drive the module, please use the DC power input of the base and set the power mode to input mode (refer to the code below), otherwise it will not start normally //mbus_mode_t: //kMBusModeOutput: Use USB or battery power //kMBusModeInput: Use external power supply 5V, or DC interface M5.begin(true, true, true, false, kMBusModeInput); //Initialize Serial according to the actual connected pins Serial2.begin(115200, SERIAL_8N1, 13, 14); The module base has a DC power input interface. Please strictly follow the input range (5-12V) to prevent damage to the module when using this interface to connect to the power supply. The internal power DIP switch can adjust the voltage level of the internal terminal VIN to adapt to different modules. Product Features CC2630F128 Quick access to the network without setting initialize the coordinator and configure the router preset, which can realize the automatic access to the network by pressing the button three times Serial communication Low power consumption (module working current: 25mA, sleep 5uA) Dynamic routing maintenance, supporting 200-level routing depth Transmission speed 250Kbps Node communication distance 1km UART transparent transmission/broadcasting/P2P Include 1x Zigbee Unit 1x SMA antenna Applications Smart Home IoT collection node Building Automation Specification Resources Parameter CC2630F128 ARM Cortex-M3 32bit communication UART 38400bps 8N1(default) Communication distance 1km (Open area) working frequency Resources 2.4GHZ (2405MHz-2480MHz, step:5MHz) Parameter DC interface specifications 5.5mm Net weight 37g Gross weight 70g Product Size 54*54*13.2mm Package Size 165*60*36mm PinMap Core TX(GPIO 0/13/17) RX(GPIO 5/15/16) 5V GND COM.Zigbee RX TX VIN GND Schematic Example Zigbee P2P CHAT ROOM Zigbee RSSI TEST EasyLoader Zigbee P2P CHAT ROOM Zigbee RSSI TEST Coordinator End Device Related Link CC2630 Datasheet Module User Manual Instructions for use of the host computer PC debugging tool Video DRFZigbee.h - API //Initialize the serial port of the module void begin(HardwareSerial & uart){ _uartp = &uart;} //Connect the module. After execution, the module will disconnect the wireless link and enter the configuration mode. int linkMoudle(); //Read and write module configuration parameters int readModuleparm(zigbee_arg_t *parm); int setModuleparm(zigbee_arg_t &parm); //Get network topology int getNetworksTopology(); //After completing the configuration, you need to execute the program to restart the module and restore the wireless connection int rebootModule(); //Get module signal quality int8_t getModuleRSSI(nodeRSSI_t *nodeRSSIPtr = nullptr); //Receive data int reviceData(reviceData_t *revice,uint8_t type = kP2PCustomIDMode,size_t timeout = 1000); //send data void sendData(uint8_t cmd, const std::initializer_list args); int sendCMDAndWaitRevice(uint8_t cmd, byteArray &array, byteArray *reviceArray = nullptr, size_t timeout = 1000); int sendCMDAndWaitRevice(uint8_t cmd, const std::initializer_list args, byteArray *reviceArray = nullptr, size_t timeout = 1000); int sendDataP2P(uint8_t mode,uint16_t addr,uint8_t *dataptr,size_t length); int sendDataP2P(uint8_t mode,uint16_t addr,byteArray &array); int sendDataP2P(uint8_t mode,uint16_t addr,const std::initializer_list args); -------------------------------------------------------------- //Module configuration parameter item DRFZigbee::zigbee_arg_t *arg = new DRFZigbee::zigbee_arg_t; uint8_t uint16_t uint8 t main_pointType; main_PANID; main channel; _ uint8_t _ ; main_transmissionMode; uint16_t main_customID; uint16_t main_res0; uint8_t main_uartBaud; uint8_t main_uartBit; uint8_t main_uatrtStop; uint8_t main_uartCheck; uint16_t main_res1; uint8_t main_ATN; uint8_t main_mac[8]; //Configure preset parameters-complete configuration preset parameters can be used to quickly access the network from the node without settings uint8_t uint16_t preset_pointType; preset_PANID; uint8_t preset_channel; uint8_t preset_transmissionMode; uint16_t preset_customID; //reserved uint16_t preset_res0; uint8_t preset_uartBaud; uint8_t preset_uartBit; uint8_t preset_uatrtStop; uint8_t preset_uartCheck; //reserved uint16_t preset_res1; uint8_t uint16_t preset_ATN; shortAddr; uint8_t res3; uint8_t encryption; uint8_t password[4];
M031-Z
PDF文档中包含以下信息: 1. 物料型号:型号为LM324,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入端,引脚2为反相输入端,引脚3为输出端,其他引脚包括电源和接地。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM324可以用于信号放大、滤波器设计、信号整形等。
6. 应用信息:适用于音频放大、传感器信号处理、医疗设备等。
7. 封装信息:提供多种封装形式,如SOIC、DIP等。
M031-Z 价格&库存
很抱歉,暂时无法提供与“M031-Z”相匹配的价格&库存,您可以联系我们找货
M031-Z
  • 1+237.006571+30.75913
M031-Z
    • 1+205.01721
    库存:50
