TailBat
SKU:T001
Description
TailBat is an external battery accessory designed for M5ATOM. If the TailBat module is inserted into the M5ATOM,it can directly supply power to
the , enabling the M5ATOM to be used in mobile applications. The TailBat contains a 190mah battery and features a physical button. It is
controlled by the power management chip IP5303. When the power is turned on, the red led will turn on,the led flashes when charging, and is
always on when fully charged. The operation method is the same as that of M5Stack Core: Click to turn on the power, double-click to turn off the
power. Since the TailBat has been designed simply to add battery power, it will not affect the original GROVE Connection mode and USB
functionality. The built-in battery can only be charged through the USB typeC interface, not through the grove interface.
Product Features
Adapted for ATOM Matrix/ATOM Lite form factor
Plug and play
Built in rechargeable lithium battery
LED indicator
M5Stick/M5StickC/M5StickV/M5Camera compatible
Include
1x TailBat
Application
ATOM portable power
Specification
Schematic
Video
Specification
Parameter
External port
1x GROVE
LED
1x RED LED
USB port
TypeC
Battery capacity
190mAh
Net weight
10g
Gross weight
10g
Product Size
55*22*14mm
Package Size
75*22*14mm
Case material
Plastic ( PC )
很抱歉,暂时无法提供与“T001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+84.288601+10.88000
