T002
T002
    M5STACK(明栈)
    RS485 接口 平台评估扩展板
T002 数据手册
Tail485 SKU:T002 Description Tail485 is a RS485 converter designed for ATOM, which is used for converting RS485 signals to TTL. RS485 is a standard defining the electrical characteristics of drivers and receivers for use in serial communications systems, widely used in the industrial field. It facilitates long distance communication in electrically noisy environments. Multipoint systems are supported. When the project equipment needs to communicate and control through RS485, it is a good choice to use Tail485 for interface type switching. A DC / DC voltage regulator chip is integrated in the tail485 module, which can directly convert the 12V voltage of RS485 to 5V to supply power for USB typeC interface, avoiding the inconvenience of a separate power supply. Product Features Adapted for ATOM Matrix/ATOM Lite form factor Built in DC / DC SP485EEN-L Inclued 1x Tail485 Application RS485 Multipoint communication Specification Specification Specification Parameter Parameter External port VH-3.96 4P Conversion level 5V12V Line Transceiver IC SP485EEN-L Step-down IC AOZ1282CI Net weight 9g Gross weight 9g Product Size 54*96*10mm Package Size 100*60*10mm Case material Plastic ( PC ) EasyLoader EasyLoader is a concise and fast firmware burner, which has a case specific program related to the product. It can flash the device quickly and simply in order to perform a test or verification of the devices function. Download Windows Version Easyloader ? Download MacOS Version Easyloader Description: Press button to send "hello",when received message the led will flashed. Related Link Datasheet SP485EEN AOZ1282CI PinMap ATOM GPIO26 GPIO32 5V GND Tail485 TX RX 5V GND Schematic Example Arduino Click here to download the Arduino example UIFlow Click here to download the UIFlow example
很抱歉,暂时无法提供与“T002”相匹配的价格&库存,您可以联系我们找货
