U001-C
U001-C
    M5STACK(明栈)
    QMP6988,SHT30 湿度,压力,温度 传感器 M5Stack 平台评估扩展板
U001-C 数据手册
ENV III SKU:U001-C Description ENV III is an environmental sensor that integrates SHT30 and QMP6988 internally to detect temperature, humidity, and atmospheric pressure data. SHT30 is a high-precision and low-power digital temperature and humidity sensor, and supports I2C interface (SHT30:0x44 , QMP6988:0x56).QMP6988 is an absolute air pressure sensor specially designed for mobile applications, with high accuracy and stability, suitable for environmental data collection and detection types of projects. Product Features Simple and easy to use High accuracy I2C communication interface HY2.0-4P interface, support platform UIFlow, Arduino 2x LEGO compatible holes Include 1x ENV-III Unit 1x HY2.0-4P Cable Applications Weather station Storage barn environment monitoring Specification Resources Parameter Maximum temperature measurement range -40 ~ 120 ℃ Highest measurement accuracy 0 ~ 60 ℃/±0.2℃ Humidity measurement range/error 10 ~ 90 %RH / ±2% Maximum measured value of air pressure/resolution/error 300 ~ 1100hPa / 0.06Pa / ±3.9Pa Communication protocol I2C: SHT30(0x44), QMP6988(0x56) Working temperature 32°F to 104°F (0°C to 40°C ) Net weight 5g Gross weight 17g Product Size 24.2*32.2*8.1mm Package Size 67*53*12mm Case Material Plastic ( PC ) ENV version scheme comparison ENV I ENV II ENV III DHT12+BMP280 SHT30+BMP280 SHT30+QMP6988 PinMap M5Core(PORT A) GPIO22 GPIO21 5V GND ENV III Unit SCL SDA 5V GND Schematic Related Link Datasheet QMP6988 SHT30 Example Arduino ENV III Unit Test
U001-C 价格&库存
很抱歉,暂时无法提供与“U001-C”相匹配的价格&库存,您可以联系我们找货
