IRSKU:U002
Description
IR is an pair of infrared photoelectric. Also from M5Go Kit, Contains 1x infrared emitter and
1x receiver. IR remote control is widely used in consumer electronics,it can be used to
operate devices such as a television set, DVD player, or other home appliance, from a short
distance. Since this unit comes with emitter and receiver, you can practice not only on IR
encode but also on IR decode.
Product Features
1x infrared emitter
1x infrared receiver
Distance range: < 5m
Software Development Platform: Arduino, UIFlow(Blockly,Python)
Two Lego-compatible holes
Product Size:32.2mm x 24.2mm x 8.9mm
Product weight:4.3g
Include
1x IR Unit
1x Grove Cable
EasyLoader
click to download EasyLoader
1.EasyLoader is a simple and fast program burner. Every product page in EasyLoader
provides a product-related case program. It can be burned to the master through simple
steps, and a series of function verification can be performed. .
2. After downloading the software, double-click to run the application, connect the M5 device to
the computer through the data cable, select the port parameters, click "Burn" to start burning.
(For M5StickC burning, please Set the baud rate to 750000 or 115200)
3. Currently EasyLoader is only suitable for Windows operating system, compatible with
M5 system adopts ESP32 as the control core host. Before installing for M5Core, you
need to install CP210X driver (you do not need to install with M5StickC as
controller)Click here to view the driver installation tutorial
Example
1. Arduino IDE
To get the complete code, please click here
2. UIFlow
Schematic
PinMap
M5Core(GROVE B)
IR Unit
GPIO36
Receiver Pin
GPIO26
5V
GND
Transmitter Pin
5V
GND
https://docs.m5stack.com/#/en/unit/ir/4-3-2
很抱歉,暂时无法提供与“U002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.866561+4.51019
