JOYSTICK
SKU:U024
Description
JOYSTICK, we have two types of JOYSTICKs one is build on a panle compatible with FACES
Kit, this is the M5Unit version of JOYSTICK
JOYSTICK is very similar to the 'analog' joystick on PS2 (PlayStation 2) controllers. The X
and Y axes are two 10k potentiometers which control 2D movement by generating analog
signals. The joystick also has a push button that could be used for special applications.
Therefore, the entire Unit can output X-Y motion signals in both directions and Z direction.
As designed in the schematic, the Joystick X dimension is connected to pin A0 of MEGA328,
the Joystick Y dimension is connected to pin A1 on MEGA328, the Joystick Z dimension is
connected to pin A2 on MEGA328.
This Unit communicates with the M5Core via the GROVE A interface. It's I2C address is
0x52. By reading the data transferred from JOSTICK, you can obtain the motion information
of JOYSTICK.
Product Features
Output value of X, Y direction: 10 ~ 250
Output value of Z direction is (0: released; 1: pressed)
Software Development Platform : Arduino, UIFlow(Blockly, Python)
Two Lego-compatible holes
Product Size:48.2mm x 24.2mm x 22.5mm
Product weight:11.4g
Include
1x JOYSTICK Unit
1x Grove Cable
Applications
Game Controller
Robot remote control
EasyLoader
EasyLoader is a concise and fast program writer, which has a built-in case program related
to the product. It can be burned to the main control by simple steps to perform a series of
function verification. Please install the corresponding driver according to the device type.
M5Core host Please click here to view the CP210X driver installation tutorial,
M5StickC/V/T/ATOM series can be used without driver)
PinMap
Mega328 ISPDownload interface Pin foot definition
Example
1. Arduino IDE
The code below is incomplete(just for usage).To get complete code, please click here
2. UIFlow
Schematic
PinMap
M5Core(GROVE A)
GPIO22
GPIO21
5V
GND
JOYSTICK Unit
SCL
SDA
5V
GND
https://docs.m5stack.com/#/en/unit/joystick/4-10-20
很抱歉,暂时无法提供与“U024”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+114.325161+14.78862
