U030
U030
    M5STACK(明栈)
    HX711 称重计 传感器 M5Stack 平台评估扩展板
U030 数据手册
WEIGHT SKU:U030 Description WEIGHT integrates a HX711 24 bits A/D chip that is specifically designed for electronic weighing device. The input multiplexer selects either Channel A or B differential input to the low-noise programmable gain amplifier (PGA). Channel "A" can be programmed with a gain of 128 or 64, corresponding to a full-scale differential input voltage of ±20mV or ±40mV respectively. when a 5V supply is connected to AVDD analog power supply pin. Channel B has a fixed gain of 32. There is no programming needed for the internal registers. All controls to the HX711 are through the pins. In the test, we have this Unit channel A to connect a pressure sensor. Then, use M5Core screen to display the weight data. Product Features Two selectable differential input channels On-chip active low noise PGA with selectable gain of 32, 64 and 128 On-chip power supply regulator for load-cell and ADC analog power supply pp pp y g gp pp y On-chip oscillator requiring no external component with optional external crystal On-chip power-on-reset Simple digital control and serial interface: pin-driven controls, no programming needed Selectable 10SPS or 80SPS output data rate Simultaneous 50 and 60Hz supply rejection Current consumption including on-chip analog power supply regulator: normal operation < 1.5mA, power down < 1uA Operation supply voltage range: 2.6 ~ 5.5V Operation temperature range: -40 ~ +85℃ 16 pin SOP-16 package Program Platform: Arduino, UIFlow(Blockly, Python) Two Lego-compatible holes Include 1x WEIGHT Unit 1x Grove Cable Applications Micro weight meter Kitchen Scale Specification Related Link Datasheet - HX711 EasyLoader Resources Parameter Operating Voltage g Operating Current g Net weight 8g Gross weight 20g Product Size 40*24*12mm Package Size 67*53*12mm download EasyLoader 1.EasyLoader is a simple and fast program burner. Every product page in EasyLoader provides a product-related case program. It can be burned to the master through simple steps, and a series of function verification can be performed. . After downloading the software, double-click to run the application, connect the M5 device to the computer through the data cable, select the port parameters, click "Burn" to start burning. (For M5StickC burning, please Set the baud rate to 750000 or 115200) Currently EasyLoader is only suitable for Windows operating system, compatible with M5 system adopts ESP32 as the control core host. Before installing for M5Core, you need to install CP210X driver (you do not need to install with M5StickC as controller)Click here to view the driver installation tutorial Schematic Pinmap If WEIGHT was connected to GROVE A M5Core(GROVE A) GPIO22 GPIO21 5V GND WEIGHT Unit DATA Pin (DAT) CLOCK Pin (CLK) 5V GND M5Core(GROVE B) GPIO36 GPIO26 5V GND WEIGHT Unit DATA Pin (DAT) CLOCK Pin (CLK) 5V GND M5Core(GROVE C) GPIO16 GPIO17 5V GND WEIGHT Unit DATA Pin (DAT) CLOCK Pin (CLK) 5V GND If WEIGHT was connected to GROVE B If WEIGHT was connected to GROVE C Example Arduino We used a pressure sensor(10kg) in this experiment. (Unit: gram) Click here to download the Arduino example UIFlow Feature Introduction HX711 is a high-precision AD conversion chip designed for electronic scales, which is converted into the corresponding weight by reading the voltage value. return to zero Reference to initial value as zero Get weight Return weight Get raw data Show rawdata Usage Click here to download the UIFlow example Last updated: 2020-12-14
很抱歉,暂时无法提供与“U030”相匹配的价格&库存,您可以联系我们找货
