U032
U032
    M5STACK(明栈)
    AT6558,MAX2659 GPS RF M5Stack 平台评估扩展板
U032 数据手册
Mini GPS/BDS Unit (AT6558) SKU: U032 This is the M5Unit version of GPS, integrates a Zhongke Weibeidou navigation chip AT6558 and a amplification chip MAX2659 used for amplifying antenna signal. AT6558 is highly performance, supports many types of satellite navigation system,able to receive satellite signals on 56 channels GNSS signal from 6 satellite navigation system, joint location, navigation, timing and more. The module is able to obtain accurate global location information. quick and accurate positioning for anywhere in the city, in the canyon, under the overhead, and inside the car. The module can be widely used in vehicle monitoring, bus reporting, car navigation, onboard navigation, notebook navigation and other products. You can plug it into port C on M5core via GROVE cable, which is a standard UART interface. UART settings : • • • • Baudrate(default: 9600bps) Start bits(1 bit) Stop bits(1 bit) Parity(no) Product Features • • • • • • Functional specification o Positioning accuracy: 2.5 meters (CEP50, open space) o Channel: 56 o Support single system positioning of BDS/GPS/GLONASS satellite navigation systems, or multi-system joint positioning in any combination o Support D-GNSS differential positioning o Positioning update frequency: 1-10Hz o Maximum height: 1800 m o Maximum speed: 515 m/s o Maximum acceleration:
很抱歉,暂时无法提供与“U032”相匹配的价格&库存,您可以联系我们找货
