Microphone Unit
SKU:U096
Description
Microphone Unit is a sound sensor with a built-in omni-directional electret microphone.
The signal is amplified and output by microphone preamplifier max4466. The amplifier can effectively suppress power supply noise and common
mode noise, and the output signal has high sound recovery and can be used in noisy environments.
The unit can not only output analog signals, but also output digital level signals. The built-in LM393 double voltage comparator can set the
comparison voltage threshold by adjusting 10K adjustable resistance.
The sensor is very suitable for acoustic electrical conversion, audio recording / sampling, FFT acoustic feedback, voice switch and other projects..
Product Features
Audio record/sample
Built-in microphone preamplifier MAX4466
Omnidirectional, 52dB sensitivity
Digital output and analog signal
Built-in dual independent precision voltage comparator and adjustable resistor, threshold adjustable
Development platform: Arduino, UIFlow (Blocky, Python)
HY2.0-4P interface
2X LEGO™ compatible holes
Include
1x Microphone Unit
1x Grove Cable
Applications
FFT Spectrum Display
Audio Sample / Record
Voice Switch
Specification
Resources
Parameter
Microphone sensitivity / SNR
52dB/40dB
Output Signal
Analog / digital
Input Voltage
5V
Net weight
5g
Gross weight
16g
Product Size
32*24*8mm
Package Size
67*53*12mm
EasyLoader
EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the
main control by simple steps to perform a series of function verification.
Download Windows Version Easyloader
Download MacOS Version Easyloader
Description:
Display the AD value collected by the microphone
Related Link
Datasheet
MAX4466
LM393
Schematic
Pin Map
M5Core(PORT B
GPIO26
GPIO36
5V
GND
Mic Unit
26
36
5V
GND
Example
Arduino
Click here to download the Arduino example
Last updated: 2020-12-14
很抱歉,暂时无法提供与“U096”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.850091+4.52886
