Catch Unit
SKU:U102
Description
Catch is a gripper that uses a SG92R servo as a power source. The servo uses a PWM signal to drive the gripper gear to rotate and control the
gripper for clamping and releasing operations. The structure adopts a design compatible with Lego 8mm round holes. You can combine it with
other Lego components to build creative control structures, such as robotic arms, gripper carts, etc.
Because the opening and closing angle of the gripper is 90° , please control the rotation angle of the driving servo to 0-45°
(PWM: freq: 50Hz, 0°-45°(pulse:0.5ms-1ms) to prevent blocking rotation. The steering gear burned out.
Product Features
SG92R steering gear
PWM signal drive
Lego hole compatible
The jaw opening and closing angle is 90°
Compatible with RoverC
Support input voltage: 4.2-6V
Development platform UIFlow, MicroPython, Arduino
Include
1x Catch Unit(Built-in Servo-SG92R)
1x HY2.0-4 adapter
1x RoverC.Pro Connector
Application
Robot gripper
Steering gear manipulator gripper
Specification
Master control resources
Parameter
Servo model
SG92R
Drive signal
Working frequency
50Hz
Clamping jaw opening and closing angle
90°
Input voltage range
4.2-6V
Work dead zone
10us
Output torque
2.5kg/cm at 4.8V
Output speed
0.1sec/60° at 4.8V
Working temperature
0°C to 55°C
Net weight
21.5g
Gross weight
50g
Product size (gripper extension)
72 x 56 x 37 mm
Package size
147 x 90 x 40 mm
Shell material
Plastic (PC )
Pin mapping
When the Catch Unit is connected to PortB, the pin mapping is as follows
M5Core(PORT B)
GPIO26
5V
GND
Catch Unit
SIGNAL
5V
GND
Example
This case controls the Catch Unit clamping jaws to perform clamping and releasing cycles.
For BASIC/M5GO/FIRE
Description: Control Catch Unit through PWM.
#include
const int servoPin = 26;
int freq = 50;
int ledChannel = 0;
int resolution = 10;
void setup() {
// put your setup code here, to run once:
M5.begin();
M5.Power.begin();
M5.Lcd.setCursor(100, 50, 4);
M5.Lcd.println("Catch Unit");
M5.Lcd.setCursor(40, 120, 4);
ledcSetup(ledChannel, freq, resolution);
ledcAttachPin(servoPin, ledChannel);
void loop() {
// High level 0.5ms is angle 0°
// duty = 0.5/20ms = 0.025, 0.025*1023≈25
ledcWrite(ledChannel, 25);
delay(2000);
// High level 1ms is angle 45°
// duty = 1/20ms = 0.05, 0.05*1023≈50
ledcWrite(ledChannel, 50);
delay(2000);
Video
很抱歉,暂时无法提供与“U102”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+61.390101+7.94117
