U107
U107
    M5STACK(明栈)
    - JRD-4035 读取器模块 840MHz ~ 960MHz 评估板
U107 数据手册
UHF-RFID SKU:U107 Description UHF-RFID is an ultra-high frequency (UHF) embedded wireless radio frequency reader module. The JRD-4035 module solution with built-in ceramic antenna completely eliminates the technical uncertainty that ordinary UHF modules need to be equipped with additional antennas for users. Optimize the RF design to realize the low power consumption and high performance of the module, and the transmission power of 100mW can reach the effective distance of more than 1.5M. Use serial communication interface, cooperate with built-in encapsulated AT command set, realize plug and play, provide good development and use experience. It is suitable for application scenarios such as warehousing logistics management and smart retail, and meets the application requirements of monitoring and reading multiple product tags. Product Features Stable recognition distance 1.5m-2m Working spectrum range: 840-960MHz Air interface protocol: EPCglobal UHF Class 1 Gen 2 ISO 18000-6C UART communication interface (baud rate: 115200bps) The buffer area can hold up to 200 tags Tag recognition is sensitive and stable Contains 1x UHF-RFID 1x HY2.0 cable (5CM) Application Warehouse logistics pallet management Vehicle management Smart retail Specifications Specifications Parameters Air interface EPCglobal UHF Class 1 Gen 2 / ISO 18000-6C protocol Work area US, Canada and other regions following U.S. FCC. Europe and other regions following ETSI EN 302 208, Mainland support China, Japan, Korea, Malaysia, Taiwan Working spectrum 840-960MHz range Tag cache area 200 tags Communication UART (Baud rate: 115200bps) protocol Net weight 41g Gross weight 58.8g Product size 56*48*11.5mm Package size 88*61*21mm Shell material Plastic (PC ) EasyLoader Windows UHF-RFID TEST Pin mapping When connecting UHF-RFID Unit to PortC, the pin mapping is as follows M5Core(PORT C) GPIO16 GPIO17 5V GND UHF-RFID Unit TXD RXD 5V GND Schematic Related Links Firmware Communication Protocol Example Arduino Click here to get the Arduino sample program Communication protocol instruction set //0. Hardware version BB 00 03 00 01 00 04 7E //1. Software version BB 00 03 00 01 01 05 7E //2.manufacturers BB 00 03 00 01 02 06 7E //3. Single polling instruction BB 00 22 00 00 22 7E //4. Multiple polling instructions BB 00 27 00 03 22 27 10 83 7E //5. Stop multiple polling instructions BB 00 28 00 00 28 7E //6. Set the SELECT parameter instruction BB 00 0C 00 13 01 00 00 00 20 60 00 30 75 1F EB 70 5C 59 04 E3 D5 0D 70 AD 7E //7. Get the SELECT parameter BB 00 0B 00 00 0B 7E //8. Set the SELECT mode BB 00 12 00 01 01 14 7E //9. Read label data storage area BB 00 39 00 09 00 00 FF FF 03 00 00 00 02 45 7E //10. Write the label data store BB 00 49 00 0D 00 00 FF FF 03 00 00 00 02 12 34 56 78 6D 7E //11. Lock the LOCK label data store BB 00 82 00 07 00 00 FF FF 02 00 80 09 7E, //12. Inactivate the kill tag BB 00 65 00 04 00 00 FF FF 67 7E //13. Set communication baud rate BB 00 11 00 02 00 C0 D3 7E //14. Get parameters related to the Query command BB 00 0D 00 00 0D 7E //15. Set the Query parameter BB 00 0E 00 02 10 20 40 7E //16. Set up work area BB 00 07 00 01 01 09 7E //17. Acquire work locations BB 00 08 00 00 08 7E //18. Set up working channel BB 00 AB 00 01 01 AC 7E //19. Get the working channel BB 00 AA 00 00 AA 7E //20. Set to automatic frequency hopping mode BB 00 AD 00 01 FF AD 7E //21. Insert the working channel BB 00 A9 00 06 05 01 02 03 04 05 C3 7E //22. Acquire transmitting power BB 00 B7 00 00 B7 7E //23. Set the transmitting power BB 00 B6 00 02 07 D0 8F 7E //24. Set up transmitting continuous carrier BB 00 B0 00 01 FF B0 7E //25. Gets the receiving demodulator parameters BB 00 F1 00 00 F1 7E //26. Set the receiving demodulator parameters BB 00 F0 00 04 03 06 01 B0 AE 7E //27. Test the RF input block signal BB 00 F2 00 00 F2 7E //28. Test the RSSI signal at the RF input BB 00 F3 00 00 F3 7E //30. Module hibernation 00 BB 00 17 00 00 17 7E //31. Idle hibernation time of module BB 00 1D 00 01 02 20 7E //32. The IDLE mode BB 00 04 00 03 01 01 03 0C 7E //33.NXP G2X label supports ReadProtect/Reset ReadProtect command BB 00 E1 00 05 00 00 FF FF 00 E4 7E //34. The NXP G2X label supports the CHANGE EAS directive BB 00 E3 00 05 00 00 FF FF 01 E7 7E //35. The NXP G2X tag supports the EAS_ALARM directive BB 00 E4 00 00 E4 7E //36.NXP G2X label 16bits config-word BB 00 E0 00 06 00 00 FF FF 00 00 E4 7E //37.Impinj Monza 4 Qt tags support Qt instructions BB 00 E5 00 08 00 00 FF FF 01 01 40 00 2D 7E //38.The BlockPermalock directive permanently locks blocks of a user's Block BB 00 D3 00 0B 00 00 FF FF 01 03 00 00 01 07 00 E8 7E Video
很抱歉,暂时无法提供与“U107”相匹配的价格&库存,您可以联系我们找货
U107
    • 1+572.10497
    库存:67
