U109-X
U109-X
    M5STACK(明栈)
    ESP32-WROOM-32E,OV2640 照相机 传感器 M5Stack 平台评估扩展板
U109-X 数据手册
Unit Camera DIY KIT SKU:U109-X Description UNIT CAMERA DIY KIT is a powerful DIY ESP32 WiFi camera kit, which includes two lens modules: Wide-angle fisheye + regular view, both using OV2640 image sensor supporting up to 200w pixel output. DIY case design, You will get a DIY model for so much fun right out of the box! Compact size, high resolution and focus capabilities they are, It's excellent for a variety of IoT image capture applications. High flexibility. Lens focus support GROVE expansion interface with programmable RGB lights Plug-and-play. Self image transfer firmware with UART/WIFI image transfer support Integrated image parameter API interface (white balance, exposure, gain, size, etc.) PC-based debugging tools Support UIFlow graphical programming platform for one-click invocation and cloud transmission Works with Arduino, ESP32-IDF and other mainstream development platforms Product Features Plug-and-play Rich image processing API interface Fascinating DIY structure model cover Built-in ESP32 MCU Includes 1x Unit CAM core board 1x OV2640 camera (FOV:66.5°) 1x OV2640 camera (FOV:160°) 1x Model Housing Kit 1x Camera Back Clip (LEGO compatible) 1x HY2.0-4P Cable Applications Remote Monitoring Camera Timer Specifications Specifications Parameters ESP32-WROOM-32E 240MHz Dual Core, 600DMIPS, 520KB SRAM, Wi-Fi, Dual Mode Bluetooth Flash 4MB Focal length 1.0±5%mm Aperture 2.2±5% Lens type 1/4inch Wide Angle Fisheye Lens Field of view 160° Pixels 200w Reverberation -135% Sensitive chip OV2640 Focal length 4.8±5%mm Aperture 2.4±5% Lens type 1/4inch Conventional view lens Field of view 65° Pixels 200w Reverberation
U109-X 价格&库存
很抱歉,暂时无法提供与“U109-X”相匹配的价格&库存,您可以联系我们找货
