U115
U115
    M5STACK(明栈)
    - ASR6501 收发器; LoRa®(LoRaWAN™) 915MHz 评估板
U115 数据手册
Unit LoRaWAN915 SKU:U115 Description Unit LoRaWAN915 is a LoRaWAN communication module suitable for 915MHz frequency launched by M5Stack. The module adopts the ASR6501 scheme, which supports long-distance communication and has both ultra-low power consumption and high sensitivity. The module integrates the LoRaWAN protocol stack and adopts a serial communication interface (using the AT command set for control). When used, it can be used as a collection node to access a large number of gateways for data collection and management. This module is suitable for long-distance low-power IoT communication applications, such as deployment of environmental monitoring nodes. ? Note: This module supports US915 band plan only. NOT supports AU915 . Product Features ASR6501 Supported US915 SMA antenna Communication interface: UART Command protocol: AT command Includes 1x Unit LoRaWAN915 1x SMA antenna Application Automatic remote meter reading Intelligent traffic intelligent parking lot Remote irrigation and environmental monitoring US915 supported countries ! Argentina / Canada / Chile / Colombia / Ecuador / Greece Guatemala / Jamaica / Mexico / Nicaragua / Panama / United States / Uruguay Specification Specifications Parameters UART baud rate 115200 Net weight 12.8g Gross weight 45g Product Size 71.5*24*8mm Package Size 95*65*25mm Related Links LoRaWAN915 AT Command LoRaWAN Regional Parameters Pin mapping M5CORE RX TX Unit LoRaWAN915 G17 G16 Schematic Example Arduino code example Video
很抱歉,暂时无法提供与“U115”相匹配的价格&库存,您可以联系我们找货
