U118
U118
    M5STACK(明栈)
    MAX30102 心率 传感器 M5Stack 平台评估扩展板
U118 数据手册
HEART RATE HAT SKU:U118 Description HEART RATE HAT is a blood oxygen heart rate sensor. Integrate MAX30102 to provide a complete pulse oximeter and heart rate sensor system solution. This is a non-pluggable blood oxygen heart rate sensor. The sensor uses I2C communication interface, internally integrates infrared lightemitting diodes, photodetectors, optical components and low-noise electronic equipment. A certain amount of ambient light suppression function can make the measurement results more accurate. . Instructions: After the program is running, place your finger on the test area with a stable and fixed pressure. Product Features Heart rate monitor and pulse oximeter sensor LED reflective solutions Integrated protective glass, sturdy and durable performance Programmable sampling rate and LED current Fast data output capability High sampling rate Strong elasticity of motion artifacts High signal-to-noise ratio Include 1x HEART RATE HAT 1x Double-sided tape Applications Wearable device Heart rate blood oxygen collector Smart Medical Specification Resources Parameter Sensor model MAX30102 Communication protocol I2C:0x57 Operating Voltage 3.3V Net weight 5.1g Gross weight 12.7g Product Size 25*24*14mm Package Size 40*40*30mm Case Material Plastic ( PC ) Related Link Datasheet MAX30102 PinMap M5StickC GPIO26 GPIO0 3.3V GND HEART RATE HAT SCL SDA 3.3V GND Schematic Example Arduino Arduino Example Code / M5StickC Plus with HEART RATE HAT Video
很抱歉,暂时无法提供与“U118”相匹配的价格&库存,您可以联系我们找货
U118
  • 1+324.424201+42.12487
