Unit LCD
SKU:U120
Description
Unit LCD is a 1.14 inch color LCD expansion screen unit. It adopts ST7789V2 drive scheme, the resolution is 135*240, and it supports RGB666
display (262,144 colors). The internal integration of ESP32-PICO control core (built-in firmware, display development is more convenient), support
through I2C (addr: 0x3E) communication interface for control and firmware upgrades. The back of the screen is integrated with a magnetic design,
which can easily adsorb the metal surface for fixing. The LCD screen extension is suitable for embedding in various instruments or control devices
that need to display simple content as a display panel.
Product Features
1.14 inch color LCD display panel
I2C communication interface
135*240 resolution
Viewing angle: full viewing angle
Magnetic back design
Support I2C firmware upgrade
Include
1x Unit LCD
1x HY2.0-4P Cable
Applications
Information display
Specification
Specification
Parameter
Working current
45.7mA
Communication protocol
I2C address: 0x3E
Display size
1.14 inch
Pixel pitch
0.1101(H) x 0.1038(V) mm
Resolution
135*240
Viewable
Full view
Operating temperature
32°F to 104°F ( 0°C to 40°C )
Net weight
8.5g
Gross weight
20g
Product Size
48*24*8mm
Package Size
67*52*12.5mm
Case material
Plastic ( PC )
PinMap
M5Core(PORT A)
GPIO22
GPIO21
5V
GND
Unit LCD
SCL
SDA
5V
GND
Schematic
Related Link
Datasheet
ST7789V2
Library
M5GFX Library
Example
Arduino
#include
M5UnitLCD display;
M5Canvas canvas(&display);
static constexpr char text[] = "Hello world ! こんにちは世界! this is long long string sample. 寿限無、寿限無、五劫の擦り切れ、海砂
利水魚の、水行末・雲来末・風来末、喰う寝る処に住む処、藪ら柑子の藪柑子、パイポ・パイポ・パイポのシューリンガン、シューリンガンのグーリ
ンダイ、グーリンダイのポンポコピーのポンポコナの、長久命の長助";
static constexpr size_t textlen = sizeof(text) / sizeof(text[0]);
int textpos = 0;
int scrollstep = 2;
void setup(void)
display.init();
display.setRotation(2);
canvas.setColorDepth(1);
// mono color
canvas.setFont(&fonts::lgfxJapanMinchoP_32);
canvas.setTextWrap(false);
canvas.setTextSize(2);
canvas.createSprite(display.width() + 64, 72);
void loop(void)
int32_t cursor_x = canvas.getCursorX() - scrollstep;
if (cursor_x 1);
About Unit LCD
Unit LCD is an I2C unit with ESP32 and ST7789V2.
It has an IPS panel with a resolution of 135 x 240.
The number of colors that can be displayed is 262,144 colors of RGB666, which is the specification of ST7789V2.
p y
p
The ESP32 is in charge of I2C communication and draws in the frame buffer in memory based on the received contents.
The contents of the frame buffer in the memory of the ESP32 are reflected in ST7789V2 by DMA transfer of SPI communication.
It is represented by RGB888 16,777,216 colors on the framebuffer.
About Communication with Unit LCD
You can send commands and receive data to the Unit LCD using I2C communication.
The maximum communication speed of I2C communication is 400kHz.
The initial value of the 7-bit address of I2C is 0x3E. It can be changed with the CHANGE_ADDR command.
The required number of bytes to send depends on the command.
Some commands complete in 1 Byte, while others require 7 Byte.
There are also indefinite length commands that do not end until communication is stopped.
If I2C communication STOP or RESTART occurs during command transmission, the interrupted command will not be processed.
It must be transmitted uninterrupted to the end in a single transmission sequence.
After sending a fixed-length command, you can send another command in succession.
After sending an indefinite-length command, I2C communication must be stopped to indicate the end of the command.
If you send a NOP command or an undefined command, the communication content is ignored until I2C communication stops.
Since the I2C communication unit and the drawing processing unit operate in parallel, I2C communication can be performed even during the drawing
processing.
The I2C communication contents are stored in the command buffer on the ESP32 memory, and the drawing processing unit processes this sequentially.
You should use the READ_BUFCOUNT command to check the remaining amount of the buffer , as sending a large amount of heavy processing, such as
extensive fill or range copy, can overwhelm the command buffer.
About drawing commands
You can draw a rectangle by filling any area with a single color with FILLRECT.
If you want to draw only one pixel, you can use DRAWPIXEL instead of FILLRECT.
If you use a command that omits the foreground color, the last used color is used.
You can specify the drawing range with CASET and RASET and send the image data with the WRITE_RAW command.
You can use WRITE_RLE instead of WRITE_RAW to send run-length compressed image data.
Command list
※ Undefined commands are treated as NOP.
hex
len
command
description
send params
[0] 0x00
0x00
1-∞
NOP
Do nothing until communication stops
[1-∞] Ignored value
0x20
1
INVOFF
Disable color inversion
[0] 0x20
0x21
1
INVON
Enable color inversion
[0] 0x21
Backlight brightness setting
[0] 0x22
0:Off - 255:Full lights
[1] Brightness(0-255)
0x22
2
BRIGHTNESS
[0] 0x23
hex
len
command
description
send params
[1] Copy source X_Left
[2] Copy source Y_Top
0x23
7
COPYRECT
Rectangle range copy
[3] Copy source X_Right
[4] Copy source Y_Bottom
[5] Copy destination X_Left
[6] Copy destination Y_Top
[0] 0x2A
0x2A
3
CASET
X-direction range selection
[1] X_Left
[2] X_Right
[0] 0x2B
0x2B
3
RASET
Y-direction range selection
[1] Y_Top
[2] Y_Bottom
Set drawing orientation
[0] 0x36
0x36
2
ROTATE
0:Normal / 1:90° / 2:180° / 3:270°
[1] Setting value (0-7)
4-7:flips 0-3 upside down
Operating speed setting
[0] 0x38
0x38
2
SET_POWER
(power consumption setting)
[1] Setting value (0-2)
0:Low speed / 1:Normal / 2:High speed
0x39
2
LCD panel sleep setting
[0] 0x39
0:wake up / 1:sleep
[1] Setting value (0-1)
SET_SLEEP
[0] 0x41
0x41
2-∞
WRITE_RAW_8
draw image RGB332
[1] RGB332
until [1] communication STOP.
[0] 0x42
0x42
3-∞
WRITE_RAW_16
draw image RGB565
[1-2] RGB565
until [1-2] communication STOP.
[0] 0x43
0x43
4-∞
WRITE_RAW_24
draw image RGB888
[1-3] RGB888
until [1-3] communication STOP.
[0] 0x44
0x44
5-∞
WRITE_RAW_32
draw image ARGB8888
[1-4] ARGB8888
until [1-4] communication STOP.
hex
0x45
len
2-∞
command
WRITE_RAW_A
description
send params
draw image A8
[0] 0x45
only alpha channel.
[1] A8
Use the last used drawing color.
[0] 0x49
0x49
3-∞
WRITE_RLE_8
draw RLE image RGB332
[1-∞] RLE Data
[0] 0x4A
0x4A
4-∞
WRITE_RLE_16
draw RLE image RGB565
[1-∞] RLE Data
[0] 0x4B
0x4B
5-∞
WRITE_RLE_24
draw RLE image RGB888
[1-∞] RLE Data
[0] 0x4C
0x4C
6-∞
WRITE_RLE_32
draw RLE image ARGB8888
[1-∞] RLE Data
draw RLE image A8
[0] 0x4D
0x4D
3-∞
WRITE_RLE_A
only alpha channel.
[1-∞] RLE Data
0x50
1
RAM_FILL
Fill the selection with the last used drawing color
[0] 0x50
[0] 0x51
0x51
2
SET_COLOR_8
Specify the drawing color with RGB332
[1] RGB332
[0] 0x52
0x52
3
SET_COLOR_16
Specify the drawing color with RGB565
[1-2] RGB565
[0] 0x53
0x53
4
SET_COLOR_24
Specify the drawing color with RGB888
[1-3] RGB888
[0] 0x54
0x54
5
SET_COLOR_32
Specify the drawing color with ARGB8888
[1-4] ARGB8888
[0] 0x60
Draw single dot
0x60
3
DRAWPIXEL
[1] X
Use the drawing color that is stored
[2] Y
[0] 0x61
0x61
4
Draw single dot
[1] X
RGB332 1Byte for drawing color specification
[2] Y
DRAWPIXEL_8
[3] RGB332
[0] 0x62
Draw single dot
0x62
5
DRAWPIXEL_16
[1] X
hex
len
command
RGB565 2Byte for drawing color specification
[2] Y
description
send params
[3-4] RGB565
[0] 0x63
0x63
6
Draw single dot
[1] X
RGB888 3Byte for drawing color specification
[2] Y
DRAWPIXEL_24
[3-5] RGB888
[0] 0x64
Draw single dot
[1] X
0x64
7
DRAWPIXEL_32
ARGB8888 4Byte for drawing color specification
[2] Y
Transparent composition with existing drawing contents
[3-6] ARGB8888
[0] 0x68
[1] X_Left
Fill rectangle
0x68
5
FILLRECT
[2] Y_Top
[3] X_Right
[4] Y_Bottom
[0] 0x69
[1] X_Left
0x69
6
Fill rectangle
[2] Y_Top
[3] X_Right
FILLRECT_8
[4] Y_Bottom
[5] RGB332
[0] 0x6A
[1] X_Left
0x6A
7
Fill rectangle
[2] Y_Top
[3] X_Right
FILLRECT_16
[4] Y_Bottom
[5-6] RGB565
[0] 0x6B
[1] X_Left
0x6B
hex
8
len
Fill rectangle
[2] Y_Top
description
send params
[3] X_Right
FILLRECT_24
command
[4] Y_Bottom
[5-7] RGB888
[0] 0x6C
[1] X_Left
Fill rectangle
[2] Y_Top
0x6C
9
FILLRECT_32
[3] X_Right
[4] Y_Bottom
[5-8] ARGB8888
[0] 0xA0
I2C address change.
[1] new I2C address.
0xA0
4
CHANGE_ADDR
prevent unintended execution,
[2] Bit inversion of [1]
[2] specifies the bit inversion value of [1].
[3] 0xA0
Command list (readable commands)
hex
len
command
description
return values
[0] 0x77
0x04
1
ID and firmware version.
[1] 0x89
4Byte received
[2] Major version
READ_ID
[3] Minor version
Get remaining command buffer.
[0] remaining command buffer (0~255)
0x09
1
READ_BUFCOUNT
The higher the value, the more room there is.
Repeated reception is possible.
Can be read out continuously.
[0] RGB332
0x81
1
READ_RAW_8
Readout of RGB332 image
Repeat [0] until communication STOP.
[0-1] RGB565
0x82
1
READ_RAW_16
Readout of RGB565 image
Repeat [0-1] until communication STOP.
[0-2] RGB888
0x83
1
READ_RAW_24
Readout of RGB888 image
Repeat [0-2] until communication STOP.
Communication example
Example: Use the Fill Rectangle command 0x6A to fill the rectangle range of X16-31 and Y32-47 with red.
index
hex
description
0x6A
Fill rectangle RGB565
1
0x10
X Left
2
0x20
Y Top
3
0x1F
X Right
4
0x2F
Y Bottom
5
0xF8
Color data RRRRRGGG(red)
6
0x00
Color data GGGBBBBB(red)
The command 6Ah is a total of 7Byte command sequence.
If an I2C communication STOP or RESTART occurs during transmission, the command will not be processed.
It is necessary to transmit without
interruption until the end in a single transmission sequence.
Any of the rectangle fill commands 68h to 6Ch can be used for rectangle fill.
Indexes 1 through 4 are the same, but indexes 5 and onward have
different methods for specifying colors.
The "remembered color" of command 68h means that the last specified color will be reused.
In other words, if you want to do several rectangular
fills of the same color in succession, you can specify the color only for the first rectangular fill and then omit the color specification by using the
68h command.
Command 6Ch, ARGB8888, allows you to specify an alpha channel (transparency), which allows you to combine the already drawn content with
the drawing color.
Example: Using the range specification command 0x2A/0x2B and the image transmission command, draw an image in the
rectangular range of X 10 to 13 and Y 14 to 17.
index
hex
description
0x2A
1
0x0A
X Left(10)
2
0x0D
X Right(13)
3
0x2B
4
0x0E
Y Top(14)
5
0x11
Y Bottom(17)
6
0x43
Draw image RGB888
7-54
Image data(RGB888 ×16)
Example: Sending an RLE (run length encoding) image using the WRITE_RLE command.
The RLE specification is based on the RLE for BMP files.
Unlike RLE for BMP files, it can be used for RGB565 and RGB888.
It first sends a consecutive number of pixels of the same color (0-255), followed by the color data.
If 0 is sent to a consecutive number, it will be in direct mode without using RLE.
In direct mode, the number of pixels (1-255) is sent first, followed by the color data for the number of pixels.
index
hex
description
0x4A
Draw RLE image RGB565
1
0x07
Consecutive number (7pixel)
2-3
0xF800
Color data (red)
Consecutive number (0pixel)
4
0x00
switch to direct mode
5
0x03
Consecutive number of direct mode(3pixel)
6-7
0x07E0
Color data (green)
8-9
0x001F
Color data (blue)
10-11
0xF800
Color data (red)
12
0x04
Consecutive number (4pixel)
13-14
0x001F
Color data (blue)
The above example will be handled as follows.
index1-3 : Draw 7 pixels of red in RLE mode.
index4-5 : Switch to direct mode and instruct it to draw 3 pixels.
index6-11: Sends the color for 3 pixels in direct mode and draws green, blue, and red.
Since the direct mode for 3 pixels is completed by index11, we will return to the RLE mode from index12.
index12-14 : Draws 4 pixels of blue in RLE mode.
Video
很抱歉,暂时无法提供与“U120”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+154.442931+19.97808
