U123
U123
    M5STACK(明栈)
    SK6812 滑动式电位计 人机接口 M5Stack 平台评估扩展板
U123 数据手册
UNIT FADER SKU:U123 Description UNIT FADER is a Slide Potentiometer with color indicator, employ a 35mm slide potentiometer + 14x SK6812 programmable RGB lights . The fader has its own center point positioning , and excellent slide appliances for stable, reliable performance and precise control. The integrated beads support digital addressing, which means you can adjust the brightness and color of each LED light. The product is suitable for lighting, music control, and other applications. Product Features With center point positioning Excellent damping Single connection 1OkΩ adjustable resistor Programmable RGB lights GROVE interface Development Platform: Arduino, UIFlow Include 1x UNIT FADER 1x HY2.0-4P Cable Application Human–machine interaction Light and music control Adjustment switch Potentiometer level signal input Specification Specification Parameter Fader stroke 35mm Fader handle length 10mm Single resistor 1OkΩ RGB LED 14x SK6812 Programmable RGB Lamp Working current 90.04mA (Lighting brightness configuration 50%, fader maximum output) Net weight 15.5g Gross weight 30g Product size 40.3 * 14 * 12.2mm Packing size 64 * 24 * 24mm Related Links ESP32 ADC DOCS FastLED Github PinMap M5Core(PORT B) G36 G26 5V GND UNIT FADER VAULE-INPUT SK6812-SIGNAL VIN GND Schematic Example Arduino FADER UNIT TEST Video
很抱歉,暂时无法提供与“U123”相匹配的价格&库存,您可以联系我们找货
U123
  • 1+69.926421+9.07518
