U127
U127
    M5STACK(明栈)
    PAJ7620U2 手势 传感器 M5Stack 平台评估扩展板
U127 数据手册
UNIT Gesture SKU:U127 Description PAJ7620U2 touchless Gesture Moving Recognition Sensor Recognise up to 9 Gestures It's a touchless 3D gesture recognition sensor via the I2C interface that integrates with PAJ7620U2 . You could feel the charm of 9 kinds of gesture recognition by default program. In addition to adding more complex gestures, the recognition rate is up to 240Hz with higher anti-interference capability. This sensor is reliable for its recognition process is intuitive and has low power consumption (operating current only 2.2mA) that allows you to control a robot in accordance with your hand's movement. This is particularly useful in interactive applications. Support 9 gestures: Up , Down , Left , Right , Front , Back , Clockwise , Counterclockwise , Quick wave Product Features PAJ7620U2 gesture sensor / I2C interface Recognizable gestures up to 9 kinds Faster, more accurate. Support for customizing and adding recognition gesture combinations (support developing) Effective recognition distance: 5cm-15cm Embedded infrared LED and optical lens, be able to work in low-light even dark environment Development Platform: Arduino, UIFlow Includes 1x UNIT Gesture 1x HY2.0-4P Cable Applications Touchless remote control Robot interaction Human-Computer Interaction Gesture light control Specification Specifications Parameters Gesture recognition frequency Typical value: 120Hz, maximum 240Hz Support gestures 9 built-in + 4 software extensions + support software algorithm expansion Effective recognition distance 5cm-15cm R Ambient light immunity
很抱歉,暂时无法提供与“U127”相匹配的价格&库存,您可以联系我们找货
U127
  • 1+114.310011+14.78340
库存:18
