UNIT ID
SKU:U124
Description
UNIT ID is a crypto coprocessor with hardware-based secure key storage, integrated with ATECC608B hardware cryptographic chip, using I2C
communication interface. The chip has a built-in 10Kb EEPROM for storing keys, certificates, data, consumption records and security
configurations. The configuration can be locked to prevent changes by restricting access to memory areas
Each ATECC608B comes with a guaranteed unique 72-bit serial number and includes several security features to prevent attacks on the device
itself, or logical attacks on data transferred between devices.
Supporting Trust&GO platform (pre-built universal certificate for TLS-based network security authentication, such as: AWS-IoT, Azure, Google and
other cloud platforms to verify registration), The internal certificate of the encryption chip can be obtained directly through the tool to complete
the automatic registration without private key exposure.
Note:
Before using this UNIT, it is recommended to read the ATECC508B datasheet, which only allows configuration prior to
locking the chip. If you need to explore the full functionality, it is recommended to purchase multiple UNIT IDs for
authentication.
Product Features
ATECC608B-TNGTLSU-G
I2C communication interface
Protective cover for extra stability and reliability
Protected storage of up to 16 keys, certificates or data
Data storage/locking
Random number generator
Preset certificates and keys
72bit unique serial number
Contains
1x Unit ID
1x HY2.0-4P cable
Applications
IoT endpoint key management and exchange
Device authentication
Data encryption
Specifications
Specifications
Parameters
Encryption chip model
ATECC608B-TNGTLSU-G
Supported algorithm types
ECC-P256 (ECDH and ECDSA), SHA256, AES128-GCM
Number of supported key storage
16
Communication interface
I2C, addr: 0x60, bus max speed 1Mbps
Power supply voltage
5V DC
Net Weight
3.2g
Gross Weight
8.3g
Product Dimensions
24 * 24 * 13mm
Package Size
35 * 36 * 18mm
Schematic
Related Links
Datasheet
ATECC608B
Example
Arduino
Github
很抱歉,暂时无法提供与“U124”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+48.564131+6.27974
