M100EVO-11B
M100EVO-11B
    LANTRONIX
    MODEM M2M GPRS RS-232
M100EVO-11B 数据手册
TECHNOLOGY GSM Quadband GPRS Class 10 Voice/Data/Fax/SMS  TCP/IP Full TCP/IP Stack INTERFACES SIM Plug-in card reader 1.8/3 V. RS232 on 15 pin Sub-D connector  Pin power supply connector 4 pin DC SMA antenna connector (50 ohm)  POWER SUPPLY Input voltage 5 to 32V DC POWER CONSUMPTION GSM 850/900 (PCL 5) 203mA at 5V DCS 1800/PCS 1900 (PCL0) 150mA at 5V GPRS 850/900 CL10 (PCL5) 388mA at 5V GPRS 1800/1900 CL10 (PCL0) 232mA at 5V Idle consumption 45mA at 5V Idle consumption (RS232 not connected) 18mA at 5V Sleep Mode 4mA at 5V CERTIFICATIONS/COMPLIANCES CE, GCF, RoHS Certification VOICE, DATA AND SMS FEATURES Data circuit asynchronous, transparent and non-transparent up to 14,400 bit/s ; Automatic fax group 3 (Class 1 and Class 2) ; MNP2, V.42bis ; Text and PDU SMS ; Point to point SMS (MT/MO) ; UCS2 Character Set Management FUNCTIONAL FEATURES AT command set (GSM 07.05, GSM > 300 07.07) FEATURES/PRODUCTS Input - Digital M100evo Crystal M100evo Lite M100evo IP N/A 1 1 Input - Analog M100evo Advanced 1 1 N/A Download Over The Air N/A Optional Autorestore - timer reset  OTHER FEATURES Operating status LED Casing  Plastic Metal Size (mm) 90x72x23 88x60x26 Weight (g) 70 100 DIMENSIONS TEMPERATURE RANGE Operating / Storage -30~+75 ˚C / -40~+85 ˚C -30~+85 ˚C / -40~+85 ˚C OPTIONAL ACCESSORIES (ADDITIONAL ACCESSORIES ARE ALSO AVAILABLE UPON REQUEST) GSM antenna 900/1800 Mhz     GSM antenna 850/1900 Mhz     RS232 cable interface     N/A    Din Clip (metal casing only) SMART PACK II FEATURES Maestro Wireless Solutions Ltd 3603-9, 36/F 118 Connaught Road West Hong Kong Tel: (852) 2869 0688 Fax: (852) 2525 4701 contact@maestro-wireless.com www.maestro-wireless.com I/O Monitoring    GPRS and IP configuration              Call Screening DynDNS Remote AT Command Ping Status check and monitoring N/A Smart Pack Lite (Local Configuration)
M100EVO-11B 价格&库存
很抱歉,暂时无法提供与“M100EVO-11B”相匹配的价格&库存,您可以联系我们找货
