MT-02B
MT-02B
    LANTRONIX
    GPS MICRO TRACKER
MT-02B 数据手册
Micro Tracker Maestro GPRS/GPS MicroTracker Maestro MicroTracker combines GSM/GPRS and GPS technologies in an industrial, compact grade design. Its exceptionally small footprint featuring embedded antennas, a single port connector make it easy to fit into most vehicles. Maestro MicroTracker provides key features for fleet management applications including reporting of position, speed mileage and ignition of the vehicle. Empowered by the latest Maestro GPS SiRF StarIV A2100-A modules, Maestro MicroTracker also provides intelligent device management functionnality like remote firmware and software upgrade and diagnostics. It’s well define parser make it easy to integrate into your back-end application server. Key Features : • Light, compact, industrial grade design • Easy to conceal • Embedded GSM and GPS antenna • Single 10 pins connector • Cutting edge Maestro GPS SiRF Star IV • GPRS & GPS LED status indicator • Optional battery back-up • Optional accelerometer and magnetometer • Intelligent device management over the air Faster Time to Market To help its customers to quickly build the link from the tracking unit to their application server, Maestro provides an embedded application featuring tracking, monitoring and geofencing capabilities. Accelerating testing phase and time to market Maestro embedding application will let you get revenues faster than ever. Micro Tracker Technical information COMMUNICATION WITH BACK-END GENERAL FEATURES - Embedded software for faster time to market - Temperature range: Or Customizable OpenAT application - Functional: -30°C to +80°C - GSM / GPRS (TCP or UDP) or SMS communication channels - Storage: -40°C to +85°C - Casing: PC/ABS material UL94V-0 flammability - Shock and Vibration : SAE J1211 STATUS INDICATORS - Dimensions: 58.6 x 60 x 13mm - One red color LED indicating GPS position fix - Weight: 45g - One green color LED indicating GSM registration ELECTRICAL CHARACTERISTICS ELECTRICAL INTERFACE - Supply voltage range: 6-32V DC - 10-pin connector - Current consumption during idle: 58mA Typical at 12V DC Connection for : - Current consumption during transmission: 104mA Typical at 12V DC - Power supply - Current consumption during power saving: 8mA Typical at 12V DC - Open collector output (able to drive external LED/relay 250mA) x2 - Digital input x2 : active between 6v to 32V DC GSM / GPRS - Analog input x1 - Wireless Microprocessor - WMP100 - approved module by AT&T; Connecting cable : PTCRB Certified & FCC Certified - Sierra Wireless - 10 pin plug - Frequency band: 850 / 900 / 1800 / 1900 MHz - Built-in antenna - Wire harness - 2A fuse on power - SIM card interface 1.8/3.0V - SIM card holder: Flip type; SIM card is accessible under the lid - Relay socket (for starter connection) FUNCTION AND FEATURE GPS - GPS engine : SiRFstar IV - Maestro A-2100-A - Positioning Accuracy : 2.5 m CEP - 2.0 m CEP SBAS - A-GPS: Embedded Extended Ephemeris and Ephemeris Push support - High sensitivity: -163dBm Tracking and -160dBm Navigation - TTFF typically
MT-02B 价格&库存
很抱歉,暂时无法提供与“MT-02B”相匹配的价格&库存,您可以联系我们找货
