VOP96L24DC
VOP96L24DC
    MAGNITUDELIGHTING
    SOLIDRIVE PRO-V, CV, PHASE CUT,
VOP96L24DC 数据手册
SOLIDRIVE PRO-V Constant Voltage Phase-Cut Dimmable LED Drivers P/N: VOP The SOLIDRIVE PRO-V Constant Voltage Class 2 LED Drivers from Magnitude Lighting are UL Listed. Drivers with enclosures have a built-in junction box on both the input and output. These drivers are IP66 and UL2043 plenum rated and are suitable for both indoor and outdoor installations. With universal input voltage ranging from 120 to 277VAC, the PRO-V Series of drivers are designed for residential, commercial and industrial applications. Our phase-cut dimming delivers smooth flicker-free dimming down to 1% with most LED’s and a wide variety of compatible dimmers. As always, a 5-year warranty is a standard on all of Magnitude’s products. Red (+) k (-) Blac UL without Junction Box 7.50" L x 2.36" W x 1.40"H Key Features • Forward & Reverse Phase-Cut Dimming • Flicker Free Dimming, Down To 1% • Universal Input Voltage – 120 to 277VAC • UL Listed Enclosure – With Built-In Junction Boxes • IP66 – For Both Indoor & Outdoor Use • Class 2, Class P • Hiccup Mode Protection For Short Circuit & Over-Temperature • Overload Protection UL with Integrated Junction Box 12.1" L x 2.36" W x 1.40"H Product Name: SOLIDRIVE PRO-V Description: Constant Voltage Phase Cut Dimmable LED Driver Installation: Can have integrated junction box with multiple 7/8" knock-outs or no junction box with wire leads Driver Type: Class 2 Single Channel Dimming: Phase cut dimming down to 1% with both Leading Edge (MLV) and Trailing Edge (ELV) dimmers Input Voltage: Universal 120VAC to 277VAC, 50/60Hz Output Voltage: 24VDC IP Rating: IP66 Listing: UL Listed Certifications: UL8750, UL2043 Plenum Rated Warranty: 5-Year Warranty MEETS TITLE 24/JA8 REQUIREMENTS Ordering Guide Example: VOP96L24DC With Junction Box Without Junction Box VOP Length 12.10" (307.9mm) 7.50” (191.6mm) Type Width 2.36” (59.9mm) 2.36” (59.9mm) VOP Height 1.40” (35mm) 1.40” (35mm) DC Max Power 96 - 96W 60 - 60W 30 - 30W Enclosure Output L - With Junction Box R - Without Junction Box 24 - 24VDC Without Junction Box With Integrated Junction Box 1.40" 1.40" (35mm) (35mm) 6.80" 11.40" (172mm) (290.5mm) 7.50" 12.10" (191.6mm) (307.9mm)  5/20/2021 Specifications subject to change without notice. REV007 WE DRIVE LIGHT SOLIDRIVE PRO-V Specification Sheet 14711 Bentley Circle, Tustin, CA 92780 www.magnitudeinc.com SOLIDRIVE PRO-V Constant Voltage Phase-Cut Dimmable LED Drivers Specifications Input Input Voltage Range: Input Frequency: Input Current: Inrush Current: Efficiency: Power Factor: THD: 96W 60W 30W 24VDC 96W 4.1A 0.95 < 20% Output Output Voltage: Max Load: Output Current @ Max Load: Output Ripple: Line Regulation: Load Regulation: Turn On Delay Time: Environmental Env. Protection Rating: Ambient Operating Temp.: Max Case Temp. (Tcase): Storage Temperature: Expected Lifetime: Audible Noise: Dimming (Dimming Models Only) Dimming Style: Min. Dimming Level: Dimming Curve: Protection Over Current Protection: Short Circuit Protection: Page 2 of 4 WE DRIVE LIGHT SOLIDRIVE PRO-V Specification Sheet REV007  5/20/2021 SOLIDRIVE PRO-V Constant Voltage Phase-Cut Dimmable LED Drivers Mechanical Diagrams With Integrated Junction Box (Drawings not to scale) 12.10" (307.9mm) 1.40" (35mm) 11.7" (297.2mm) 1.45" (36.8mm) 1.37" 2.36" (34.8mm) (59.9mm) 11.4" (290mm) 0.69" 0.39" 2.30" (17.53mm) 9.91mm 58.42mm 0.07" (1.78mm) 1.27" (32.3mm) 0.66" (16.76mm) Knockout Ø0.86" (21.84mm) diameter Mounting Flange Holes Ø0.16" (4.06mm) diameter 1.45" 36.83mm 1.04" 1.88" (26.42mm) 47.75mm 2.67" (67.82mm) Knockout Ø0.86" 0.11" (2.8mm) (21.84mm) diameter 2.00" 50.8mm REV007  5/20/2021 WE DRIVE LIGHT SOLIDRIVE PRO-V Specification Sheet Page 3 of 4 SOLIDRIVE PRO-V Constant Voltage Phase-Cut Dimmable LED Drivers Mechanical Diagrams Without Integrated Junction Box (Drawings not to scale) 1.40" 1.40" 0.10" (35.6mm) (35mm) (2.54mm) 6.80" 1.90" (172mm) (48.3mm) 7.50" (191.6mm) Input 1.45" (36.8mm) 16mm 1c 80ºc max 95mm black green white Output black red Mounting Flange Holes Ø0.20" (5.08mm) diameter 2.36 (182.9mm) 7.20" (182.9mm) Wiring Diagram Dimmer (Optional) Red (+) Line / Hot Wire (Black) Neutral Wire (White) Green Wire Ground Page 4 of 4 LED Driver Black (-) WE DRIVE LIGHT SOLIDRIVE PRO-V Specification Sheet REV007  5/20/2021
VOP96L24DC 价格&库存
很抱歉,暂时无法提供与“VOP96L24DC”相匹配的价格&库存,您可以联系我们找货
