CVD96L24DC
CVD96L24DC
    MAGNITUDELIGHTING
    SOLIDRIVE, CV, 0-10V, LISTED, 96
CVD96L24DC 数据手册
SOLIDRIVE P/N: CV Constant Voltage Electronic 0-10V & Non-Dimmable LED Driver UL without Junction Box The SOLIDRIVE is an electronic Class 2, 0-10V dimmable LED driver with an available integrated junction box, making it the perfect choice for tape lighting, tube lighting, linear lighting and multiple other commercial lighting applications. The UL enclosure is IP66 and UL2043 plenum rated and are suitable for both indoor and outdoor installations; each includes a separate input and output wiring compartment with three ⅞" knockouts for easy installation. The driver features hiccuup mode, over current and short circuit protection – as well as an efficiency over 84%, resulting in low operating case temperature. The SOLIDRIVE is dimmable down to 1% with a 0-10V dimmer and is also available in a non-dimmable version. Installation: Can have integrated junction box with multiple 7 /8" knock-outs – or no junction box with wire leads Driver Type: Class 2 Single Channel Dimming: 0-10V dimmable down to 1%; non-dimmable available Input Voltage: Universal 120VAC to 277VAC, 50/60Hz Output Voltage: 12, 24, 36, or 48VDC Environmental: Dry & damp IP Rating: IP66 Listing: Available in UL Listed, Class P, Type HL Certifications: UL8750, UL2043 Plenum Rated Warranty: 5-Year Ordering Guide CV TYPE CV – Constant Voltage DC 7.50" L x 2.36" W x 1.40"H UL with Integrated Junction Box 12.1" L x 2.36" W x 1.40"H MEETS TITLE 24/JA8 REQUIREMENTS SOLIDRIVE is also available in:  JB-SERIES (Junction Box Series)  EZJBOX (EZ Junction Box Series) Please refer to our website at Magnitudeinc.com for more details. Example: CVN50L12DC DIMMING MAX POWER LISTING N – Non-Dimming D – Dimming 30¹ 50² 60¹ 96³ - 30W 50W 60W 96W OUTPUT L - With Junction Box R - Without Junction Box 12 - 12VDC 24 - 24VDC 36 - 36VDC 48 - 48VDC Length Width Height With Junction Box Without Junction Box 12.10" (307.34mm) 7.50" (190.5mm) 2.36" (59.94mm) 2.36" (59.94mm) 1.40" (35.6mm) 1.40" (35.6mm) ¹24 & 48VDC only ²12VDC only ³24, 36, & 48VDC only With Integrated Junction Box Without Junction Box 1.40" 1.40" (35.6mm) (35.6mm) 6.80" 11.40" (172.72mm) (289.6mm) 7.50" 12.10" (190.5mm) (307.34mm)  5/20/2021 Specifications subject to change without notice. REV004 WE DRIVE LIGHT SOLIDRIVE Specification Sheet 14711 Bentley Circle, Tustin, CA 92780 www.magnitudeinc.com SOLIDRIVE Constant Voltage Electronic 0-10V & Non-Dimmable LED Driver Specifications Input Input Voltage Range: Input Frequency: Input Current: Inrush Current: Efficiency: Power Factor: THD: 30W 50W 60W 96W 120 - 277VAC ± 10% 50 / 60Hz 0.96A Max (24VDC) 0.96A Max (48VDC) 5A Max@120VAC 30A Max@277VAC > 84% Max (24VDC) > 84% Max (48VDC) 120 - 277VAC ± 10% 50 / 60Hz 0.96A Max 120 - 277VAC ± 10% 50 / 60Hz 0.96A Max 120 - 277VAC ± 10% 50 / 60Hz 0.96A Max 6A Max@120VAC 30A Max@277VAC > 80% Max 5A Max@120VAC 30A Max@277VAC > 84% Max > 0.95 > 0.95 5A Max@120VAC 30A Max@277VAC > 84% Max (24VDC) > 84% Max (36VDC) > 84% Max (48VDC) > 0.95 < 20% < 20% < 20% 24VDC / 48VDC 30W 1.3A (24VDC) 625mA Max(48VDC) 12VDC 50W 4.2A 24VDC 60W 2.6A < 3% < 2% < 3% (24VDC) < 1% (48VDC) < 3% < 2% < 5% < 3% < 2% < 3% < 0.3 sec < 0.3 sec < 0.3 sec 24VDC / 36VDC / 48VDC 96W 4.1A (24VDC) 2.7A (36VDC) 2.0A (48VDC) < 3% < 2% < 3% (24VDC) < 3% (36VDC) < 1% (48VDC) < 0.3 sec IP66 -25°C - +40°C (-13°F - 104°F) 80°C (176°F) -40°C - +85°C (-40°F - 185°F) 50k hours (>65°C) Tc < 24dB Class A IP66 -25°C - +40°C (-13°F - 104°F) 80°C (176°F) -40°C - +85°C (-40°F - 185°F) 50k hours (>65°C) Tc < 24dB Class A IP66 -25°C - +40°C (-13°F - 104°F) 80°C (176°F) -40°C - +85°C (-40°F - 185°F) 50k hours (>65°C) Tc < 24dB Class A IP66 -25°C - +40°C (-13°F - 104°F) 80°C (176°F) -40°C - +85°C (-40°F - 185°F) 50k hours (>65°C) Tc < 24dB Class A 0-10V 1% Linear 0.2mA Max Source / Sinc 0-10V 1% Linear 0.2mA Max Source / Sinc 0-10V 1% Linear 0.2mA Max Source / Sinc 0-10V 1% Linear 0.2mA Max Source / Sinc Yes Yes Yes / Hiccup Mode Yes / Current Limit Yes / Current Limit Yes Yes Yes / Hiccup Mode Yes / Current Limit Yes / Current Limit Yes Yes Yes / Hiccup Mode Yes / Current Limit Yes / Current Limit Yes Yes Yes / Hiccup Mode Yes / Current Limit Yes / Current Limit > 0.91 (24VDC) > 0.95 (48VDC) < 20% Output Output Voltage: Max Load: Output Current @ Max Load: Output Ripple: Line Regulation: Load Regulation: Turn On Delay Time: Environmental Env. Protection Rating: Ambient Operating Temp.: Max Case Temp. (Tcase): Storage Temperature: Expected Lifetime: Audible Noise: Dimming (Dimming Models Only) Dimming Control: Min. Dimming Level: Dimming Curve: Current Consumption: Protection Over Current Protection: Over Voltage Protection: Over Temperature Protection: Over Load Protection: Short Circuit Protection: Page 2 of 5 WE DRIVE LIGHT SOLIDRIVE Specification Sheet REV004  5/20/2021 SOLIDRIVE Constant Voltage Electronic 0-10V & Non-Dimmable LED Driver Mechanical Diagrams With Integrated Junction Box (Drawings not to scale) 12.10" (307.34mm) 1.40" (35.6mm) 11.7" (297.2mm) 1.45" (36.83mm) 1.37" 2.36" (34.8mm) (59.94mm) 11.4" (289.6mm) 0.69" 0.39" 2.30" (17.53mm) 9.91mm 58.42mm 0.07" (1.78mm) 1.27" (32.26mm) 0.66" (16.76mm) Knockout Ø0.86" Mounting Flange Holes Ø0.16" (4.06mm) diameter 1.04" 1.88" (26.42mm) 47.75mm 2.67" (67.82mm) (21.84mm) diameter 1.45" 36.83mm 0.11" (2.79mm) Knockout Ø0.86" (21.84mm) diameter 2.00" 50.8mm REV004  5/20/2021 WE DRIVE LIGHT SOLIDRIVE Specification Sheet Page 3 of 5 SOLIDRIVE Constant Voltage Electronic 0-10V & Non-Dimmable LED Driver Mechanical Diagrams Without Integrated Junction Box (Drawings not to scale) 1.40" 1.40" 0.10" (35.6mm) (35.6mm) (2.54mm) 6.80" 1.90" (172.72mm) (48.26mm) 7.50" (190.5mm) Input 1.45" (36.83mm) 0.63" (16mm) 1c 80ºc max 3.74" (95mm) Output Black black green Red white Mounting Flange Holes Ø0.20" (5.08mm) diameter 2.36 (59.94mm) 7.20" (182.88mm) Page 4 of 5 WE DRIVE LIGHT SOLIDRIVE Specification Sheet REV004  5/20/2021 SOLIDRIVE Constant Voltage Electronic 0-10V & Non-Dimmable LED Driver Wiring Diagrams Non-Dimmable Configuration White (N) Neutral Wire Red (+) LED Driver Black (L) Line Wire Black (-) Green (Ground Wire) ( ) Dimmable Configuration Red (+) White (N) Neutral Wire Black (-) LED Driver Black (L) Line Wire Gray Purple Green (Ground Wire) ( ) Compatible 0-10V Dimmers REV004  Dimming Part Number Lutron Lutron Lutron Leviton Watt Stopper Lightolier Controls Philips Diva - DVTV Diva - NFTV Nova T - NTFTV Illumitech - IP7 DCLV1 ZP600FAM120 Sunrise - SR1200ZTUNV 5/20/2021 Output Power (W) 0-10V Dimmer Dimming Curve 100 96W Max 80 60 40 20 0 0 2 4 6 8 10 12 Dimming Voltage (V) WE DRIVE LIGHT SOLIDRIVE Specification Sheet Page 5 of 5
CVD96L24DC 价格&库存
很抱歉,暂时无法提供与“CVD96L24DC”相匹配的价格&库存,您可以联系我们找货
