10021
10021
    MAKEBLOCK(创客工场)
    ME ORION ATMEGA328 EVAL BRD
10021 数据手册
Me Orion (Base on Arduino UNO)  SKU: 10021 Weight: 45.00 Gram Description: Makeblock Orion is an easy-to-use mainboard based on Arduino Uno with improvements for education. It provides eight RJ25 ports to connect to all the other Me series modules with color-labels, can save you from horrible pin-wiring and help you focus on inventor amazing projects. Makeblock Orion supports most of programming software (Arduino/ Scratch/ AduBlock), and we offer the customized graphical programming software (Scratch for Robot/ Makeblock HD App). You can also find Makeblock Base Bracket which is compatible with Orion here. Features:       100% Arduino compatible; Comes with Arduino library for easy programming; Working with mBlock inspired by Scratch 2.0, cover all ages people; Using RJ25 cable connect the Me series electronic modules, super easy to wiring; Modular installation, and compatible with LEGO Bricks; Two-channel motor driver integrated (Two channels additional with Me-motor driver through PORT_1&2) Specification: Operating Voltage: 6-12V DC power; Microcontroller: ATmega238; Detecting Angle: prefer at 30 degree angle; Dimension: 80 x 60 x 18mm (Length x Width x Height); Usage:   Connect the Makeblock Orion and computer with micro-USB cable first. The first time you use Makeblock Orion, you need to install the USB interface driver. Makeblock Orion support PC and mobile device control.                                                     http://store.makeblock.com/me‐orion‐base‐on‐arduino‐uno 11‐15‐17
10021 价格&库存
很抱歉,暂时无法提供与“10021”相匹配的价格&库存,您可以联系我们找货
