11048
11048
    MAKEBLOCK(创客工场)
    ME PM2.5 SENSOR
11048 数据手册
      Me PM2.5 Sensor SKU: 11048 Weight: 90.00 Gram  The PM2.5 sensor laser detect atmospheric PM2.5 with laser scattering theory. It features highprecision detection, rapid response and steady operation, with minimal errors. The sensor can detect a range of PM1.0 to PM10. Features •Detect atmospheric PM2.5 with laser scattering theory •High-precision detection, rapid response and operation, with minimal errors •Particulate Measurement Range: 0.3 ~ 10 μm •Support mBlock GUI programming •Adopt RJ25 port for easy connection mBlock – PM2.5 Gas Sensor Extended Instructions Me PM2.5 sensor supports mBlock programming. If you use the PM2.5 sensor by mBot (mCore mainboard), then you need to install a custom firmware.To install custom firmware, Click here. After installing the firmware, refer to the following procedure to use the PM2.5 sensor. Performance Parameters •Supply Voltage: 5V DC •Operating Temperature: -10°C ~ 65°C •Control Mode: Dual-Digital Interface Control •Particulate Measurement Range: 0.3 ~ 10 um •Dimensions (L x W x H)48mm*65mm*24mm   Assembly Procedure PM2.5 Sensor Schematic Diagram Click here to download. http://download.makeblock.com/Me%20PM2.5%20Sensor%20V2_PCB.pdf https://store.makeblock.com/me-pm-2-5-sensor/2-15-18
11048 价格&库存
很抱歉,暂时无法提供与“11048”相匹配的价格&库存,您可以联系我们找货
