13400
13400
    MAKEBLOCK(创客工场)
    ME RGB LED V1
13400 数据手册
Me RGB LED SKU:13400 Weight:10.00 Gram         Description: Me RGB LED V1.0 is a shiny Me series module which has 4 full color ws2812 RGB LEDs. With integrated chip, you can control each LED individually to adjust its brightness and creat any color by mixing different amounts of red, green, blue. It is cost effective for you using in shiny lighting interative project such as decorating your robot or room. Features:       4 full color RGB LED with intergrated chip which can be controled individually A buildin fuse protects the RGB LED from over current or any shortage by any reasons 16mm interval M4 mounting holes, compatible with Makeblock beams 2.54mmbreakout pins for connecting with jumper wires Easy wiring with 6 Pin RJ25 interface Arduino library for easy programming Specification:    RatedVoltage: 5V Peak current : 60mA each with 240mA in total Size:24x48x 32mm(Length x Width x Height)        http://store.makeblock.com/me‐rgb‐led 11‐16‐17
13400 价格&库存
很抱歉,暂时无法提供与“13400”相匹配的价格&库存,您可以联系我们找货
