13620
13620
    MAKEBLOCK(创客工场)
    IR CONTROLLER V2
13620 数据手册
    IR Controller SKU: 13620 Weight: 30.00 Gram  What is IR controller? The IR controller is designed to wirelessly control robots and other mechanical device. Working with many common IR receiver, this IR controller provides you a simple and easy way to control your devices without touching it! (Picture for reference only. please go through part list before purchasing.) Feature Integration ? Compatible with Makeblock robots and software; ? Aim the IR controller at the IR receiver from a short distance; ? Works with the NEC IR protocol. Various Buttons This IR controller comes with 21 buttons, including buttons labeled from letter "A" to "F", number buttons started from 0 to 9, and four direction buttons. These buttons allow you to control your robot in a more precise way.   About Battery This IR controller does NOT include a coin cell battery. We recommend that you use a CR2025 coin cell battery to get this IR controller work.   Specifications Operating Voltage 2.25V to 3.9V Operating Current 6mA to 25mA Quiescent Current ≤3uA Infrared wavelength 940±50nm Carrier Frequency 37.9±0.2KHZ Power Supply 3V CR2025 coin cell battery Working Temperature -40~85 Dimension (L*W*H) 90 x 41 x 12mm Net Weight 25g (0.8oz)                                                           https://store.makeblock.com/ir‐controller 8‐7‐18
13620 价格&库存
很抱歉,暂时无法提供与“13620”相匹配的价格&库存,您可以联系我们找货
