50220
50220
    MAKEBLOCK(创客工场)
    MICRO PERISTALTIC PUMP DC12.0V
50220 数据手册
Micro Peristaltic Pump DC12.0V SKU: 50220 Weight: 120.00 Gram Note: This pump does NOT come with connecting wire, please choose motor cable of corresponding current to work with it. Micro Peristaltic Pump (DC12.0V) is a new type of micro liquefied pump that has mini size and powerful function. With easy-to-use feature, it can be used in a DIY project or an industrial project. The pump body comes with triple-roller and environmental-friendly silicone hosepipe. Having no valve and sealing, the silicone hosepipe can be easily replaced. The liquid won't be in direct contact with the pump body, hence more environmentfriendly and pollution-free. The Micro Peristaltic Pump can also be used to pump sensitive liquid and organic solvent. Internal structure as below: Features:      Support for positive and negative transfer. High accurateness in flow control. D(1.5-4)mm*0.5m silicone tube is included for using. Environmental protection silicone tube for food and medical industry. Simple structure and low maintenance. Specifications:     Voltage: DC 12.0V Flow Velocity: (6~24)ml/min Operating Temperature: 0~40Ԩ Relative Humidity < 80% Size Chart(mm): Demo: Part List: 1 x D(1.5-4)mm*0.5m Silicone Tube 1 x Micro Peristaltic Pump https://store.makeblock.com/micro-peristaltic-pump-dc12-0v/2-15-18
50220 价格&库存
很抱歉,暂时无法提供与“50220”相匹配的价格&库存,您可以联系我们找货
