59030
59030
    MAKEBLOCK(创客工场)
    MINI CYLINDER MSI8X20UFA
59030 数据手册
        Single Acting Mini Cylinder Pack MSI8X20UFA SKU: 59030 Weight: 55.00 Gram    Description: It is a mini cylinder of single acting extrusion type with a bore size of 8mm and stroke of 20mm. The installation method is panel installation and the mounting nut is M12X1.25. It is equipped with a exhaust silencer, used with M5-φ4 quick plug connector and its theoretical thrust is 18.6N under the pressure of 0.5MPa. Features:     Mini & small and easy to install. Single acting extrusion type and reset by a reset spring. The theoretical thrust is 18.6N under the pressure of 0.5MPa. Used with M5-φ4 quick plug connector. Size Charts(mm): Connection Illustration:                    https://store.makeblock.com/single‐acting‐mini‐cylinder‐pack‐msi8x20ufa/2‐7‐19
59030 价格&库存
很抱歉,暂时无法提供与“59030”相匹配的价格&库存,您可以联系我们找货
