60018
60018
    MAKEBLOCK(创客工场)
    SLIDE BEAM0824-080-BLUE PAIR
60018 数据手册
        Slide Beam0824-080-Blue (Pair) SKU: 60018 Weight: 35.00 Gram What Is Slide Beam0824-080? Slide Beam0824-080 is a frequently-used mechanical part of Makeblock platform,and also compatibles with most Makeblock mechanical components. There are various mounting holes and a threaded slot on the plane of this beam which allow you to assemble on other structures easily. Features ? Made from heavy-duty 6061 aluminum extrusion ? With holes on 16mm increments,and M4 threaded holes on both ends ? Cross-section area 8x24mm, length 80mm ? High wear resistance and high intensity ? Strong rigidity DEMO Size Charts Specifications   SKU 60018 Product Name Slide Beam0824-080-Blue (Pair) Length 80mm Cross-section Area 8 x 24mm Gross Weight 35g (1.23oz) Package Content (Quantity x Part Name) 2x Slide Beam0824-080                                                   https://store.makeblock.com/slide‐beam0824‐080‐blue‐pair/2‐7‐19
60018 价格&库存
很抱歉,暂时无法提供与“60018”相匹配的价格&库存,您可以联系我们找货
