60014
60014
    MAKEBLOCK(创客工场)
    SLIDE BEAM0824-064-BLUE(PAIR)
60014 数据手册
Slide Beam0824-064-Blue (Pair) SKU: 60014 Weight: 28.00 Gram https://sketchfab.com/models/d24d0ffe874b4ffd8b424f8cb54687db/embed What Is Slide Beam0824-064? Slide Beam0824-064 is a frequently-used mechanical part of Makeblock platform,and also compatibles with most Makeblock mechanical components. There are various mounting holes and a threaded slot on the plane of this beam which allow you to assemble on other structures easily. Features ? Made from heavy-duty 6061 aluminum extrusion ? With holes on 16mm increments,and M4 threaded holes on both ends ? Cross-section area 8x24mm, length 64mm ? High wear resistance and high intensity ? Strong rigidity DEMO Size Charts Specifications SKU 60014 Product Name Slide Beam0824-064-Blue (Pair) Length 64mm Cross-section Area 8 x 24mm Gross Weight 28g (0.99oz) Package Content (Quantity x Part Name) 2x Slide Beam0824-064 https://store.makeblock.com/slide-beam0824-064-blue-pair/2-18-19
60014 价格&库存
很抱歉,暂时无法提供与“60014”相匹配的价格&库存,您可以联系我们找货
