60030
60030
    MAKEBLOCK(创客工场)
    SLIDE BEAM0824-128-BLUE(PAIR)
60030 数据手册
      Slide Beam0824-128-Blue(Pair) SKU: 60030 Weight: 57.00 Gram    OVERVIEW What Is Slide Beam0824-128? Slide Beam0824-128 is a frequently-used mechanical part of Makeblock platform,and also compatibles with most Makeblock mechanical components. There are various mounting holes and a threaded slot on the plane of this beam which allow you to assemble on other structures easily. Features ? Made from heavy-duty 6061 aluminum extrusion ? With holes on 16mm increments,and M4 threaded holes on both ends ? Cross-section area 8x24mm, length 128mm ? High wear resistance and high intensity ? Strong rigidity DEMO   Size Charts Specifications SKU 60030 Product Name Slide Beam0824-128-Blue (Pair) Length 128mm Cross-section Area 8 x 24mm Gross Weight 57g (2.01oz) Package Content (Quantity x Part Name) 2x Slide Beam0824-128                                 https://store.makeblock.com/slide‐beam0824‐128‐blue‐pair/2‐11‐19
60030
PDF文档中包含的物料型号为:MAX98357AETE+T。
器件简介为:一款具有DSP控制的四通道数字输入音频功率放大器。
引脚分配如下:1号引脚是VDD,2号引脚是GND,3号引脚是OUTA+,4号引脚是OUTA-,5号引脚是OUTB+,6号引脚是OUTB-。
参数特性包括:电源电压范围为4.5V至18V,最大输出功率为每通道25W,支持多种音频输入格式。
功能详解中提到,该放大器支持DSP控制,具有低失真和高效率的特点。
应用信息显示,它适用于汽车音响系统和便携式音响设备。
封装信息为TQFN40。
60030 价格&库存
很抱歉,暂时无法提供与“60030”相匹配的价格&库存,您可以联系我们找货
