60701
60701
    MAKEBLOCK(创客工场)
    BEAM0412-036-BLUE 4PC
60701 数据手册
    Beam0412-036-Blue (4-Pack) - Robot Kit Part SKU: 60701 Weight: 12.00 Gram What Are Beams? Beams are the most frequently-used parts of Makeblock platform which can be used to build all kinds of mechanical structures. Beam 0412 series is usually applied as linking-rod parts and comes with different length varying from 36mm to 236mm for various building needs. Versatile Usage • Works perfectly with Plastic Gear, Timing Pulley, other wheel-related parts, and motor shafts; • Build various linking-rod structures thru different combinations; • Can be used with angular sensor to enables angle feedback between 2 linking-rod parts; • Equipped with slots for easy and flexible connection with Beam 0808 & 0824. Design & Material • Compatible with most Makeblock motions and structure components; • Made from heavy-duty 6061 aluminum extrusion with anodized surface for long-time use; • With 4mm diameter through-holes on 16mm increments. Note This page is for Beam 0412-036 with length of 36mm. For other configuration, please search Beam 0412 in our website. Building Examples:   Size Chart (mm): Specifications SKU 60701 Material 6061 Aluminum Diameter of holes 4mm Cross-section area 4 x 12mm Length 36mm Package content 4 x Beam 0412-036 Dimension 36 x 12 x 4mm (1.42 x 0.47 x 0.16'') Net Weight 12g (0.42oz)                                     https://store.makeblock.com/beam0412‐036‐blue‐4‐pack/2‐7‐19
60701 价格&库存
很抱歉,暂时无法提供与“60701”相匹配的价格&库存,您可以联系我们找货
