60711
60711
    MAKEBLOCK(创客工场)
    BEAM0412-108-BLUE 4PC
60711 数据手册
      Beam0412-108-Blue (4-Pack) SKU: 60711 Weight: 38.40 Gram What Are Beams? Beams are the most frequently-used parts of Makeblock platform which can be used to build all kinds of mechanical structures. Beam 0412 series is usually applied as linking-rod parts and comes with different length varying from 36mm to 236mm for various building needs. Versatile Usage • Works perfectly with Plastic Gear, Timing Pulley, other wheel-related parts, and motor shafts; • Build various linking-rod structures thru different combinations; • Can be used with angular sensor to enables angle feedback between 2 linking-rod parts; • Equipped with slots f   Design & Material • Compatible with most Makeblock motions and structure components; • Made from heavy-duty 6061 aluminum extrusion with anodized surface for long-time use; • With 4mm diameter through-holes on 16mm increments. Note This page is for Beam 0412-108 with length of 108mm. For other configuration, please search Beam 0412 in our website. Building Examples:   Size Chart (mm):       Specifications SKU 60711 Material 6061 Aluminum Diameter of holes 4mm Cross-section area 4 x 12mm Length 108mm Package content 4 x Beam 0412-108 Dimension 108 x 12 x 4mm (4.25 x 0.47 x 0.16'') Net Weight 38.4g (1.35oz)                                                               https://store.makeblock.com/beam0412‐108‐blue‐4‐pack/2‐25‐19
60711 价格&库存
很抱歉,暂时无法提供与“60711”相匹配的价格&库存,您可以联系我们找货
