60715
60715
    MAKEBLOCK(创客工场)
    BEAM0412-140-BLUE 4PC
60715 数据手册
       Beam0412-140-Blue (4-Pack) SKU: 60715 Weight: 50.40 Gram    What Are Beams? Beams are the most frequently-used parts of Makeblock platform which can be used to build all kinds of mechanical structures. Beam 0412 series is usually applied as linking-rod parts and comes with different length varying from 36mm to 236mm for various building needs. Versatile Usage • Works perfectly with Plastic Gear, Timing Pulley, other wheel-related parts, and motor shafts; • Build various linking-rod structures thru different combinations; • Can be used with angular sensor to enables angle feedback between 2 linking-rod parts; • Equipped with slots for easy and flexible connection with Beam 0808 & 0824. Design & Material • Compatible with most Makeblock motions and structure components; • Made from heavy-duty 6061 aluminum extrusion with anodized surface for long-time use; • With 4mm diameter through-holes on 16mm increments. Note This page is for Beam 0412-140 with length of 140mm. For other configuration, please search Beam 0412 in our website. Building Examples:   Size Chart (mm):     Specifications SKU 60715 Material 6061 Aluminum Diameter of holes 4mm Cross-section area 4 x 12mm Length 140mm Package content 4 x Beam 0412-140 Dimension 140 x 12 x 4mm (5.51 x 0.47 x 0.16'') Net Weight 50.4g (1.78oz)                                                           https://store.makeblock.com/beam0412‐140‐blue‐4‐pack/2‐26‐19
60715 价格&库存
很抱歉,暂时无法提供与“60715”相匹配的价格&库存,您可以联系我们找货
