60717
60717
    MAKEBLOCK(创客工场)
    BEAM0412-156-BLUE 4PC
60717 数据手册
         Beam0412-156-Blue (4-Pack) SKU: 60717 Weight: 56.80 Gram What Are Beams? Beams are the most frequently-used parts of Makeblock platform which can be used to build all kinds of mechanical structures. Beam 0412 series is usually applied as linking-rod parts and comes with different length varying from 36mm to 236mm for various building needs. Design & Material • Compatible with most Makeblock motions and structure components; • Made from heavy-duty 6061 aluminum extrusion with anodized surface for long-time use; • With 4mm diameter through-holes on 16mm increments. Note This page is for Beam 0412-156 with length of 156mm. For other configuration, please search Beam 0412 in our website. Building Examples:     Size Chart (mm):       Specifications SKU 60717 Material 6061 Aluminum Diameter of holes 4mm Cross-section area 4 x 12mm Length 156mm Package content 4 x Beam 0412-156 Dimension 156 x 12 x 4mm (6.14 x 0.47 x 0.16'') Net Weight 56.8g (2oz)                                                           https://store.makeblock.com/beam0412‐156‐blue‐4‐pack/2‐26‐19
60717 价格&库存
很抱歉,暂时无法提供与“60717”相匹配的价格&库存,您可以联系我们找货
