60719
60719
    MAKEBLOCK(创客工场)
    BEAM0412-172-BLUE 4PC
60719 数据手册
     Beam0412-172-Blue (4-Pack) SKU: 60719 Weight: 62.40 Gram What Are Beams? Beams are the most frequently-used parts of Makeblock platform which can be used to build all kinds of mechanical structures. Beam 0412 series is usually applied as linking-rod parts and comes with different length varying from 36mm to 236mm for various building needs. Versatile Usage • Works perfectly with Plastic Gear, Timing Pulley, other wheel-related parts, and motor shafts; • Build various linking-rod structures thru different combinations; • Can be used with angular sensor to enables angle feedback between 2 linking-rod parts; • Equipped with slots for easy and flexible connection with Beam 0808 & 0824. Design & Material • Compatible with most Makeblock motions and structure components; • Made from heavy-duty 6061 aluminum extrusion with anodized surface for long-time use; • With 4mm diameter through-holes on 16mm increments. Note This page is for Beam 0412-172 with length of 172mm. For other configuration, please search Beam 0412 in our website. Building Examples: Size Chart (mm):   Specifications SKU 60719 Material 6061 Aluminum Diameter of holes 4mm Cross-section area 4 x 12mm Length 172mm Package content 4 x Beam 0412-172 Dimension 172 x 12 x 4mm (6.77 x 0.47 x 0.16'') Net Weight 62.4g (2.2oz)                                                        https://store.makeblock.com/beam0412‐172‐blue‐4‐pack/2‐26‐19
60719
物料型号为Beam 0412-172,是Makeblock平台中常用的机械结构部件,通常作为连杆使用。
该系列有多种长度,从36mm到236mm不等,以满足不同的构建需求。
器件简介: Beam 0412系列与塑料齿轮、同步带轮、其他与轮子相关的部件以及电机轴完美配合使用;可以通过不同的组合构建各种连杆结构;可以与角度传感器一起使用,实现两个连杆部件之间的角度反馈;配备有插槽,便于与Beam 0808和0824灵活连接。
引脚分配: Beam 0412-172具有4mm直径的通孔,以16mm的增量分布。
参数特性: - 材质:6061铝合金 - 孔径:4mm - 横截面积:4x12mm - 长度:172mm - 包装内容:4个Beam 0412-172 - 尺寸:172x12x4mm (6.77x0.47x0.16英寸) - 净重:62.4g (2.2oz)
功能详解应用信息: Beam 0412-172可以用于构建各种机械结构,与Makeblock的运动和结构组件兼容,适用于需要角度反馈的场合。
封装信息: Beam 0412-172采用重型6061铝合金挤压材料制成,表面阳极氧化处理,适用于长期使用。
60719 价格&库存
很抱歉,暂时无法提供与“60719”相匹配的价格&库存,您可以联系我们找货
