60722
60722
    MAKEBLOCK(创客工场)
    BEAM0412-188-L2-R1-BLUE 4PC
60722 数据手册
    Beam0412-188-Blue (4-Pack) SKU: 60721 Weight: 70.40 Gram  What Are Beams? Beams are the most frequently-used parts of Makeblock platform which can be used to build all kinds of mechanical structures. Beam 0412 series is usually applied as linking-rod parts and comes with different length varying from 36mm to 236mm for various building needs. Versatile Usage • Works perfectly with Plastic Gear, Timing Pulley, other wheel-related parts, and motor shafts; • Build various linking-rod structures thru different combinations; • Can be used with angular sensor to enables angle feedback between 2 linking-rod parts; • Equipped with slots for easy and flexible connection with Beam 0808 & 0824. Design & Material • Compatible with most Makeblock motions and structure components; • Made from heavy-duty 6061 aluminum extrusion with anodized surface for long-time use; • With 4mm diameter through-holes on 16mm increments Note This page is for Beam 0412-188 with length of 188mm. For other configuration, please search Beam 0412 in our website. Building Examples:   Size Chart (mm):   Specifications SKU 60721 Material 6061 Aluminum Diameter of holes 4mm Cross-section area 4 x 12mm Length 188mm Package content 4 x Beam 0412-188 Dimension 188 x 12 x 4mm (7.40 x 0.47 x 0.16'') Net Weight 70.4g (2.48oz)   https://sketchfab.com/models/ef1239fff7c5430e808eae9d5f3fad23/embed                                                     https://store.makeblock.com/beam0412‐188‐blue‐4‐pack/2‐19‐19
60722 价格&库存
很抱歉,暂时无法提供与“60722”相匹配的价格&库存,您可以联系我们找货
