60725
60725
    MAKEBLOCK(创客工场)
    BEAM0412-220-BLUE 4PC
60725 数据手册
    Beam0412-220-Blue (4-Pack) SKU: 60725 Weight: 82.40 Gram What Are Beams? Beams are the most frequently-used parts of Makeblock platform which can be used to build all kinds of mechanical structures. Beam 0412 series is usually applied as linking-rod parts and comes with different length varying from 36mm to 236mm for various building needs. Versatile Usage • Works perfectly with Plastic Gear, Timing Pulley, other wheel-related parts, and motor shafts; • Build various linking-rod structures thru different combinations; • Can be used with angular sensor to enables angle feedback between 2 linking-rod parts; • Equipped with slots for easy and flexible connection with Beam 0808 & 0824. Design & Material • Compatible with most Makeblock motions and structure components; • Made from heavy-duty 6061 aluminum extrusion with anodized surface for long-time use; • With 4mm diameter through-holes on 16mm increments. Note This page is for Beam 0412-220 with length of 220mm. For other configuration, please search Beam 0412 in our website. Building Examples:     Size Chart (mm):     Specifications   SKU 60725 Material 6061 Aluminum Diameter of holes 4mm Cross-section area 4 x 12mm Length 220mm Package content 4 x Beam 0412-220 Dimension 220 x 12 x 4mm (8.66 x 0.47 x 0.16'') Net Weight 82.4g (2.91oz)  https://sketchfab.com/models/bf3197fabec7499dafd3d78575e36614/embed                                                    https://store.makeblock.com/beam0412‐220‐blue‐4‐pack/2‐19‐19
60725 价格&库存
很抱歉,暂时无法提供与“60725”相匹配的价格&库存,您可以联系我们找货
