61236
61236
    MAKEBLOCK(创客工场)
    PLATE 0324-088-BLUE PAIR
61236 数据手册
    Plate 0324-088-Blue (Pair) SKU: 61236 Weight: 25.00 Gram What Are Plates? Plates are the most frequently-used mechanical parts which can be connected with various beams to build robot structures. Various diameter of holes on the plate also allow you to connect with bearings and motors easily. Plate 0324 series comes with different length varying from 40mm to 88mm for various building needs. (Picture for reference only. please go through part list before purchasing.) Feature Integration ? Made from heavy-duty 6061 aluminum extrusion with anodized surface for long-time use; ? Comes with various 4mm holes and 8mm holes that meet your different needs; ? 3mm thickness, high-intensity but light-weight.   Note This page is for Plate 0324-088 with length of 88mm. For other configuration, please search "Plate 0324" in our website. Building Examples: Size Chart (mm): Specifications SKU 61236  Material  6061 Aluminum  Diameter of holes  4mm, 8mm  Cross‐section area  3 x 24mm  Length  88mm  Package content  2 x Plate0324‐088  Dimension (L*W*H)  88 x 24 x 3 mm (3.46×0.94×0.12 inch)  Gross weight  20g (0.71oz)     https://store.makeblock.com/image/cache/catalog/61236/6‐800x800.jpg                                                 https://store.makeblock.com/plate‐0324‐088‐blue‐pair/2‐7‐19
61236 价格&库存
很抱歉,暂时无法提供与“61236”相匹配的价格&库存,您可以联系我们找货
