62436
62436
    MAKEBLOCK(创客工场)
    F16 CYLINDER BRACKET L1 - BLUE
62436 数据手册
                φ16 Cylinder Bracket L1 - Blue   SKU: 62436 Weight: 15.00 Gram  φ16 Cylinder Bracket L1 is suitable for cylinders with a bore size of 10mm (such as Makeblock Double Acting Mini Cylinder MI16X100CA). As a L-shaped bracket, it can be installed on the head, the bottom, or both sides of a cylinder. The long-hole design ensures the bracket to be compatible with Beam0824 and Beam 2424, hence realizes the function of fixing the cylinder. Features:    Diameter of the big round hole: φ16.2; Diameter of the long holes: φ4.1; Length of the long hole: 8mm. Size Chart (mm): Product Dimension Height/Width/Length: 24 x 18 x 34 mm (0.94 x 0.71 x 1.34 inch) Package Dimension Height/Width/Length: 80 x 130 x 18 mm (3.15 x 5.12 x 0.71 inch)     Part List: 1 x φ16 Cylinder Bracket L1 - Blue        https://store.makeblock.com/16‐cylinder‐bracket‐l1‐blue/2‐25‐19
62436 价格&库存
很抱歉,暂时无法提供与“62436”相匹配的价格&库存,您可以联系我们找货
