62441
62441
    MAKEBLOCK(创客工场)
    U BRACKET U3 - BLUE
62441 数据手册
    U Bracket U3 - Blue SKU: 62441 Weight: 15.00 Gram U Bracket U2 is mostly used to connect with the tail of a mini cylinder with a bore size of 16mm. It will enable the cylinder to swing around the bracket. Meanwhile, with 4mm Makeblock-compatible hole, the U Bracket U2 can also be used as a regular structure part for building, such as fixing Beam 0808, Beam 0824, etc. Features:    Opening width: 12mm; Diameter of all holes: 4.1mm; Pitch of holes: 8mm. Size Chart (mm): Product Dimension Height/Width/Length: 18 x 24 x 26mm (0.71 x 0.94 x 1.02 inch) Package Dimension Height/Width/Length: 80 x 130 x 18 mm (3.15 x 5.12 x 0.71 inch) Part List: 1 x U Bracket U3 - Blue        https://store.makeblock.com/u‐bracket‐u3‐blue/2‐26‐19
62441 价格&库存
很抱歉,暂时无法提供与“62441”相匹配的价格&库存,您可以联系我们找货
