69003
69003
    MAKEBLOCK(创客工场)
    360*256MM ALUMINIUM SHEET
69003 数据手册
    360 x 256 x 3mm Aluminum Sheet SKU: 69003 Weight: 657.00 Gram What Is Aluminum Sheet? Aluminum Sheet is high-strength sheet designed for building large size robots. The various standard holes and slots on this sheet allows you to connect with any parts, modules, or devices on the movement platform to achieve any functions you like. Features ? Various standard holes and slots; ? Fully compatible with Makeblock mechanical parts; ? Can be assembled with any parts or modules to realize various interesting functions; ? Ideal sheet for building large size robots. Building Example Using this ultra-large aluminum plate as chassis, together with 100mm Mecanum wheels, Makeblock mechanical parts and electronic modules, you can build a big robot car that fulfill more needs.  Demo: Size Chart (mm): Specifications SKU 69003 Product Name 360 x 256 x 3mm Aluminum Sheet Weight 657 g Type Board/Sheet Material Aluminum Alloy Dimension (L*W*H) 360mm x 256mm x 3mm Package Content (Quantity x Part Name) 1 x 360 x 256mm Aluminum Sheet                                                           https://store.makeblock.com/360‐256mm‐aluminium‐sheet/2‐25‐19
69003 价格&库存
很抱歉,暂时无法提供与“69003”相匹配的价格&库存,您可以联系我们找货
